HP 1000 All-in-One i5-7500 8GB 256GB SSD Win 10 Pro
Quicklinx: D527WS00 Mfr#: 2LU11EA#ABU
  • Core i5
Impressive performance that fits right in. The design looks amazing. Your business performance will look even better. Trust your mission-critical projects to an all-in-one PC that's built to handle the demands of virtually any business environment. Power your workday with a secure, enterprise-class PC that's easy to manage and just as reliable as it is stylish.
  • Let nothing stand in your way
    Super-charge your HP PC with Windows 10 Pro and a 7th Gen Intel Core processor with optional Intel Optane memory.
  • Choose from three optional display sizes
    Pick the right display to suit your needs. Choose from a touch or non-touch 60.45 cm (23.8") diagonal, 68.58 cm (27") diagonal non-touch, and a 86.36 cm (34") diagonal non-touch curved display for an immersive and engaging visual experience.
  • The adaptable all-in-one
    With core computing components like 7th Gen Intel Core i3/i5/i7 processors located in the base of our most serviceable AiO, you can upgrade or redeploy displays as user and business needs change over time.
  • Give your speakers a boost
    HP Audio Boost balances loudness and clarity, and enhances bass for improved speech quality.
  • Cut out the chatter
    Suppress background noise including keyboard clicks with HP Noise Cancellation.
  • Browse confidently
    HP Sure Click provides hardware-enforced security for web browsers, protecting your PC from websites infected with malware, ransomware or viruses.
HP EliteOne 1000 G1 - all-in-one - Core i5 7500 3.4 GHz - 8 GB - SSD 256 GB - LED 23.8"
Personal computer - all-in-one
Intel Core i5 (7th Gen) 7500 / 3.4 GHz (, up to 3.8 GHz, (Quad-Core)
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
6 MB
Cache Per Processor
6 MB
RAM
8 GB (installed) / 32 GB (max) - DDR4 SDRAM
Storage Controller
SATA
Hard Drive
SSD 256 GB - PCI Express - M.2 2280 - NVM Express (NVMe)
Optical Storage
No optical drive
Monitor
23.8" - LED - 1920 x 1080 (Full HD) - 16:9
Graphics Controller
Intel HD Graphics 630
Camera
Audio Output
Stereo
1GbE
OS Provided
Windows 10 Pro 64-bit Edition
Software Included
HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, HP Velocity, HP Client Catalog, HP Driver Packs, HP BIOS Config Utility, HP JumpStart, HP Sure Connect, HP Noise Cancellation, HP System Software Manager, HP LAN-WLAN Protection, HP BIOSphere Gen3, HP JetAdvantage, HP PhoneWise, HP Management Integration Kit for Microsoft System Center Configuration Manager (free download)
53.95 cm x 19 cm x 41.92 cm
8.21 kg
Limited warranty - parts and labour - 3 years
Personal computer
Product Form Factor
All-in-one
Built-in Devices
Fingerprint reader
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Clock Speed
3.4 GHz
Max Turbo Speed
3.8 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Chipset Type
Intel Q270
Cache Memory
Installed Size
6 MB
Cache Per Processor
6 MB
RAM
Installed Size
8 GB / 32 GB (max)
DDR4 SDRAM
Effective Memory Speed
2400 MHz
Rated Memory Speed
2400 MHz
SO-DIMM 260-pin
Slots
2 (Total) / 1 (empty)
Dual channel memory architecture
Configuration Features
1 x 8 GB
Hard Drive
SSD - M.2 2280
1 x 256 GB
Interface Type
PCI Express
NVM Express (NVMe)
Storage Controller
1 x SATA
Optical Storage
No optical drive
Monitor
Monitor Type
LED - IPS
Diagonal Size
23.8"
Native Resolution
Widescreen Display
Image Aspect Ratio
16:9
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Colour Gamut
72% NTSC
Pixel Pitch
0.2745 mm
Image Brightness
250 cd/m²
Image Contrast Ratio
1000:1
Monitor Features
Full HD anti-glare, 72% NTSC colour gamut
Graphics Controller
Graphics Processor
Video Interfaces
HDMI, DisplayPort
Audio Output
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
High Definition Audio
Speakers Included
2 x right / left channel
Camera
Camera
Resolution (MP)
2 Megapixel (rear), 2 Megapixel (front)
Resolution
Full HD
IR camera, Windows Hello
Audio Input
Dual array microphone
Ethernet Controller
Intel I219-LM
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.1x, IEEE 802.11i, IEEE 802.3az
Bays
1 (total) / 1 (free) x internal 2.5"
Slots
1 (total) / 0 (free) x CPU , 2 (total) / 1 (free) x SO-DIMM 260-pin , 1 (total) / 1 (free) x M.2 Card - 2230 , 1 (total) / 0 (free) x M.2 Card - 2280
5 x USB 3.1 Gen 1 (two of them with wake functionality, one of them is charging) , 1 x DisplayPort input , 1 x DisplayPort output , HDMI output , 1 x LAN (Gigabit Ethernet) , 1 x headphones , 1 x USB 3.1 - Type C
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Low halogen
Power adapter
Power Provided
180 Watt
Efficiency
87%
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Windows 10 Pro 64-bit Edition English
Software
53.95 cm
19 cm
41.92 cm
8.21 kg
10 °C
35 °C
10 - 90%
Warranties (1)
D527 HP Care Pack Next Business Day HW Support Post Warranty Extended Service Agreement 1 Year On-Site In Stock £27.41
Other bundles (2)
D527 HPE DisplayPort To VGA Adapter In Stock £12.06
D527 HPE DisplayPort DVI-D Adapter In Stock £11.06
