Impressive performance that fits right in. The design looks amazing. Your business performance will look even better. Trust your mission-critical projects to an all-in-one PC that's built to handle the demands of virtually any business environment. Power your workday with a secure, enterprise-class PC that's easy to manage and just as reliable as it is stylish.
Let nothing stand in your way
Super-charge your HP PC with Windows 10 Pro and a 7th Gen Intel Core processor with optional Intel Optane memory. -
Choose from three optional display sizes
Pick the right display to suit your needs. Choose from a touch or non-touch 23.8-inch diagonal, 27-inch diagonal non-touch, and a 34-inch diagonal non-touch curved display for an immersive and engaging visual experience. -
The adaptable all-in-one
With core computing components like 7th Gen Intel Core i3/i5/i7 processors located in the base of our most serviceable AiO, you can upgrade or redeploy displays as user and business needs change over time. -
Give your speakers a boost
HP Audio Boost balances loudness and clarity, and enhances bass for improved speech quality. -
Cut out the chatter
Suppress background noise including keyboard clicks with HP Noise Cancellation. -
Browse confidently
HP Sure Click provides hardware-enforced security for web browsers, protecting your PC from websites infected with malware, ransomware or viruses.
- HP EliteOne 1000 G1 - all-in-one - Core i5 7500 3.4 GHz - 8 GB - SSD 256 GB - LED 27"
- Personal computer - all-in-one
- Localisation
- Processor
- Intel Core i5 (7th Gen) 7500 / 3.4 GHz (, up to 3.8 GHz, (Quad-Core)
- Processor Main Features
- Intel Turbo Boost Technology 2
- RAM
- 8 GB (installed) / 32 GB (max) - DDR4 SDRAM - PC4-19200
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- SSD 256 GB - PCI Express - M.2 2280 - NVM Express (NVMe)
- Optical Storage
- No optical drive
- Monitor
- 27" - LED - 3840 x 2160 (Ultra HD 4K) - 16:9
- Graphics Controller
- Intel HD Graphics 630
- Camera
- Audio Output
- Stereo
- Networking
- 1GbE
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Pro 64-bit Edition
- Software Included
- HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, HP Velocity, HP Client Catalog, HP Driver Packs, HP BIOS Config Utility, HP JumpStart, HP Sure Connect, HP Noise Cancellation, HP System Software Manager, HP LAN-WLAN Protection, HP BIOSphere Gen3, HP JetAdvantage, HP PhoneWise, HP Management Integration Kit for Microsoft System Center Configuration Manager (free download)
- 61.33 cm x 19 cm x 45.73 cm
- 10.2 kg
- Environmental Standards
- ENERGY STAR Qualified
- Personal computer
- Product Form Factor
- All-in-one
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 3.4 GHz
- Max Turbo Speed
- 3.8 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- Chipset Type
- Intel Q270
RAM
- Installed Size
- 8 GB / 32 GB (max)
- Technology
- DDR4 SDRAM
- Effective Memory Speed
- 2400 MHz
- Rated Memory Speed
- 2400 MHz
- Memory Specification Compliance
- PC4-19200
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total) / 1 (empty)
- Dual channel memory architecture
- Configuration Features
- 1 x 8 GB
Hard Drive
- SSD - M.2 2280
- Capacity
- 1 x 256 GB
- Interface Type
- PCI Express
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
Optical Storage
- No optical drive
Monitor
- Monitor Type
- LED - IPS
- Diagonal Size
- 27"
- Native Resolution
- Widescreen Display
- Image Aspect Ratio
- 16:9
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Colour Gamut
- 99% sRGB
- Pixel Pitch
- 0.1554 mm
- Image Brightness
- 350 cd/m²
- Image Contrast Ratio
- 1000:1
- Monitor Features
- Tilt stand, Ultra HD 4K anti-glare, 99% sRGB colour gamut
Graphics Controller
- Graphics Processor
- Video Interfaces
- HDMI, DisplayPort
Audio Output
- Sound Output Mode
- Stereo
- Max Sampling Rate
- 192 kHz
- High Definition Audio
- Speakers Included
- 2 x right / left channel
Camera
- Camera
- Resolution (MP)
- 2 Megapixel (rear), 2 Megapixel (front)
- Resolution
- Full HD
- IR camera, Windows Hello
Audio Input
- Dual array microphone
- Ethernet Controller
- Intel I219-LM
- Data Link Protocol
- Bays
- 1 (total) / 1 (free) x internal 2.5"
- Slots
- 1 (total) / 0 (free) x CPU , 2 (total) / 1 (free) x SO-DIMM 260-pin , 1 (total) / 1 (free) x M.2 Card - 2230 , 1 (total) / 0 (free) x M.2 Card - 2280
- 4 x USB 3.1 Gen 1 , 1 x DisplayPort input , 1 x DisplayPort output , HDMI output , 1 x LAN (Gigabit Ethernet) - RJ-45 , 1 x headphones , 2 x USB-C 3.1 (one of them is fast-charging)
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Low halogen
- Power adapter
- Voltage Required
- Power Provided
- 180 Watt
- Efficiency
- 87%
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Windows 10 Pro 64-bit Edition English
- Software
Sustainability Information
- ENERGY STAR Certified
- 61.33 cm
- 19 cm
- 45.73 cm
- 10.2 kg
- 10 °C
- 35 °C
- 10 - 90%
Warranties (1)
HP Care Pack Next Business Day HW Support Post Warranty Extended Service Agreement 1 Year On-Site | In Stock | £16.86 |
Monitors (1)
HP DreamColour 31.1" 4096x2160 10ms 2xHDMI 2xDisplayPort USB-C LED Monitor | In Stock | £2,821.06 |
Other bundles (1)
HPE DisplayPort To VGA Adapter | In Stock | £13.72 |
