HP  P24q G4 23.8" 2560x1440 5ms VGA HDMI IPS LED Monitor
Quicklinx: GS0VWS00 Mfr#: 8MB10AA#ABU
Diagonal Size: 23.8in
Max Resolution: 2560 x 1440
Response Time: 5ms
Speakers: None
Interfaces: VGA (HD-15), HDMI
£155.56 ex VAT
£186.67 inc VAT
Enjoy a stylish, height-adjustable display with sharp QHD resolution and ultra-wide viewing angles on the HP P24q 23.8" Monitor. This ultra slim, 3-sided micro-edge display comes at a great value with convenient HDMI and VGA connectivity.
  • Find your sweet spot
    Filter blue light emission and shift colors to a warmer spectrum for more comfortable viewing with HP Low Blue Light mode. Adjust tilt for your best view.
  • Divide and conquer
    Manage your display and make it work for you. HP Display Assistant allows you to quickly resize screen partitions so you can work in separate regions of the screen and helps deter theft by dimming a display that's disconnected without approval.
  • We have your back
    We're just a call or click away. Rest assured that your IT investment is supported with our three-year standard limited warranty. To extend your protection, select an optional HP Care service.
HP P24q G4 - P-Series - LED monitor - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Class
Class G
Power Consumption (On mode)
26 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440 at 60 Hz
Pixel Pitch
0.2058 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 10000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Gamut
99% sRGB
Input Connectors
HDMI, VGA
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
54.06 cm x 21.16 cm x 46.33 cm
5.59 kg
English / United Kingdom
Plug and Play, BSMI, NOM, WHQL, CB, CCC, FCC, ISO 9241-307, ICES, S Mark, cTUVus, TUV Bauart, China Energy Label Level 2, CEC, ERP, CECP, CEL, EAC, UAE, Ukraine Energy Label
3-year warranty
Display Type
Energy Class
Class G
Diagonal Size
23.8"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2058 mm
Pixel Per Inch
123
Brightness
250 cd/m²
Contrast Ratio
Colour Gamut
99% sRGB
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
50 - 60 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Colour Temperature
6500K
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
High Frame Rate Control (Hi-FRC), Flicker Free technology, 3-sided micro-edge, 6-bit + FRC Color Depth
54.06 cm x 21.16 cm x 46.33 cm - with stand
5.59 kg
HDMI ¦ VGA
Mechanical
Tilt Angle
-5/+23
Swivel Angle
360
Rotation Angle
90
Height Adjustment
100 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand, VESA interface support, HDCP Compliant, arsenic free, mercury free
1 x HDMI cable - 1.8 m
Backlight Life
30,000 hours
Security Slot Type
Kensington security slot
Input Voltage
26 W
26 kWh/1000h
Power Consumption (Typical)
26 Watt
Power Consumption Stand by
0.5 Watt
Dimensions & Weight Details
With stand - width: 54.06 cm - depth: 21.16 cm - height: 46.33 cm - weight: 5.59 kg , Without stand - width: 54.06 cm - depth: 4.69 cm - height: 32.25 cm - weight: 3.42 kg
Shipping Width
63.9 cm
Shipping Depth
22.5 cm
Shipping Height
41.9 cm
Shipping Weight
7.59 kg
Limited warranty - parts and labour - 3 years - on-site
5 °C
35 °C
20 - 80% (non-condensing)
Accessories (1)
GS0V HP B250 Mounting Kit for LCD Display/Thin Client In Stock £20.08
Warranties (4)
GS0V HP Care Pack Next Business Day Hardware Support Extended Service Agreement 4 Years On-Site In Stock £22.36
GS0V HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site In Stock £32.96
GS0V HP Care Pack Next Business Day Hardware Support Extended Service Agreement 1 Year On-Site In Stock £5.89
GS0V HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Yrs On-Site for Monitor In Stock £10.59
Response Time: 5ms
Speakers: None
Interfaces: HDMI
Brand: HP
