Enjoy the reliable HP Wired Mouse X500 that conveniently connects to your computer via USB. The contoured shape comfortably fits the natural arch of the hand and can be programmed to work with either hand. Simply plug in and navigate seamlessly with the responsive optical tracking.
1
Designed with your comfort in mind, the elongated arch and contoured shape provides relaxed control for either right or left-hand users. -
2
With a simple inserting the USB cord you power your mouse and avoid ever replacing batteries. No software or downloads. Just start scrolling and clicking away. -
3
Navigate Windows 8, Windows Vista, Windows 7, or Windows XP with the convenient 3 control buttons and central scroll wheel. -
4
The optical tracking technology provides ideal tracking on most surfaces for accurate and smooth control.
- HP X500 - mouse - USB
- Mouse
- Connectivity Technology
- Wired - USB
- Orientation
- Right and left-handed
- 6.35 cm x 11.51 cm x 3.538 cm
- 106 g
- Movement Detection Technology
- Optical
- Buttons Qty
- 3
- Scrolling wheel
- OS Required
- Apple MacOS X, Microsoft Windows Vista / XP / 7 / 8
- Microsoft Certification
- Compatible with Windows 7
- Mouse
- Orientation
- 6.35 cm
- 11.51 cm
- 3.538 cm
- 106 g
Input Device
- Wired
- Interface
- USB
- Optical
- Buttons Qty
- 3
- Scrolling wheel
- 1 x USB - 4 pin USB Type A
- OS Required
- Shipping Width
- 14 cm
- Shipping Depth
- 12 cm
- Shipping Height
- 5.5 cm
- Shipping Weight
- 0.2 kg
