HP  Mouse X500
HP Mouse X500
Quicklinx: B3DXWS00 Mfr#: E5E76AA#ABB
Recommended Use: Leisure
Type: Mouse
Wired / Wireless: Wired
Colour: Black
Compatibility: Mac, PC
£9.16 ex VAT
£10.99 inc VAT
Enjoy the reliable HP Wired Mouse X500 that conveniently connects to your computer via USB. The contoured shape comfortably fits the natural arch of the hand and can be programmed to work with either hand. Simply plug in and navigate seamlessly with the responsive optical tracking.
  • 1
    Designed with your comfort in mind, the elongated arch and contoured shape provides relaxed control for either right or left-hand users.
  • 2
    With a simple inserting the USB cord you power your mouse and avoid ever replacing batteries. No software or downloads. Just start scrolling and clicking away.
  • 3
    Navigate Windows 8, Windows Vista, Windows 7, or Windows XP with the convenient 3 control buttons and central scroll wheel.
  • 4
    The optical tracking technology provides ideal tracking on most surfaces for accurate and smooth control.
HP X500 - mouse - USB
Mouse
Wired - USB
Orientation
Right and left-handed
6.35 cm x 11.51 cm x 3.538 cm
106 g
Movement Detection Technology
Optical
Buttons Qty
3
Scrolling wheel
Apple MacOS X, Microsoft Windows Vista / XP / 7 / 8
Microsoft Certification
Compatible with Windows 7
Mouse
Orientation
6.35 cm
11.51 cm
3.538 cm
106 g
Input Device
Wired
USB
Optical
Buttons Qty
3
Scrolling wheel
1 x USB - 4 pin USB Type A
Shipping Width
14 cm
Shipping Depth
12 cm
Shipping Height
5.5 cm
Shipping Weight
0.2 kg
Type: Mouse
Colour: Black
Compatibility: Mac
Compatibility: PC
Brand: HP
