HP - Disk drive - DVD-RW - USB - External
CLEARANCE!
Clearance
Quicklinx: CKLQWS00 Mfr#: F2B56ET
  • DVD-RW
Connect the HP External USB DVD/RW to any available USB port on your PC to get immediate read/write access to your optical media.
Back up your data, move files, enjoy your multimedia, and read and write CDs and DVDs2 to your heart’s content with a compact external ODD.
Keep your workspace tidy and add an ODD only when you need it. Connect the USB-powered drive to any USB 2.0 or 3.0 port on your PC and you’re ready to go. No additional AC adapter is required.
Enjoy the reassurance of a one-year parts replacement limited warranty.
  • USB plug and play
    No power adapter needed. The USB cable connects to your PC's USB 2.0 or 3.0 ports allowing for easy data transfer and constant power for the external drive.
  • OS compatible
    Conveniently works with the Windows 7, Windows 8 and Windows 10, Mac 10.4 or later and Chrome operating systems, so navigate and create with familiarity.
  • Media storage
    Create your own DVD movies, music CDs, or store that big presentation. The dual layer technology allows you to store twice as much data up to 8.5 GB of storage.
  • Performance protection
    To offset data transfer interruptions and slowdowns the drive utilizes buffer under-run protection to eliminate writing errors.
HP DVD-RW drive - USB - external
DVD-RW drive - external
USB
Optical Storage
DVD-RW
Manufacturer Selling Program
HP Smart Buy
USB
Optical Storage
DVD-RW
1 x USB
HP Smart Buy
