HP - DDR5 - module - 16 GB - SO-DIMM 262-pin - 5600 MHz / PC5-44800
Quicklinx: HS7NWS00 Mfr#: 83P91AA
More than 50 In Stock
£96.98 ex VAT
£116.37 inc VAT
Upgrade your capacity for uninterrupted, undeterred, unbelievably fast speed. Upgrading to 16 GB DDR5 5600MHz SODIMM to open up your workspace to its full potential. Make way for all the things you need to get done, at once, with state-of-the-art processing power.
Memory module
16 GB
Memory Type
DDR5 SDRAM - SO-DIMM 262-pin
Upgrade Type
System specific
Speed
5600 MHz (PC5-44800)
Voltage
1.1 V
EliteBook 1040 G10 Notebook, 840 G10 Notebook, 845 G10 Notebook, 860 G10 Notebook, 865 G10 Notebook; ZBook Firefly 14 G10 Mobile Workstation, 16 G10 Mobile Workstation; ZBook Fury 16 G10 Mobile Workstation, 16 G11 Mobile Workstation
16 GB
Upgrade Type
System specific
70 mm
30 mm
2.5 mm
9 g
DRAM memory module
DDR5 SDRAM
SO-DIMM 262-pin
Speed
Voltage
1.1 V
232 mm x 148 mm x 10 mm / 53 g
HP EliteBook 1040 G10 Notebook, 840 G10 Notebook, 845 G10 Notebook, 860 G10 Notebook, 865 G10 Notebook , HP ZBook Firefly 14 G10 Mobile Workstation, 16 G10 Mobile Workstation , HP ZBook Fury 16 G10 Mobile Workstation, 16 G11 Mobile Workstation
Brand: HP
