HP - DDR4 - 4 GB - DIMM 288-pin - 2400 MHz / PC4-19200
Quicklinx: CKLYWS00 Mfr#: T9V38AT
Boost the capabilities of your HP Workstation and improve system performance and application responsiveness with low-power, high-speed DDR4 memory from HP.
  • Flexible, fast scalability
    Improve start-up times with fewer delays during routine operations, run more programs simultaneously, and easily toggle between them with super-fast memory that you can scale to meet your exact requirements.
  • HP-tested
    Ensure that all of your memory characteristics match by upgrading with HP-branded memory that's been tested for seamless system-level integration with HP Workstations.
  • Benefit from integrated ECC
    Help avoid errors that can corrupt data sets and introduce system issues with Error Checking and Correcting technology that corrects single-bit memory errors.
  • Supported by HP
    Protect your investment with the same world-class HP limited warranty you get for your HP Workstation.
HP - DDR4 - module - 4 GB - DIMM 288-pin - 2400 MHz / PC4-19200 - registered
Memory module
4 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
2400 MHz (PC4-19200)
Registered
Voltage
1.2 V
HP 852260-001, HP T9V38AT
Manufacturer Selling Program
HP Smart Buy
Workstation Z440, Z640, Z840
4 GB
Upgrade Type
System specific
DRAM memory module
DDR4 SDRAM
DIMM 288-pin
Speed
ECC
Registered
Chips Organization
512 x 8
Voltage
1.2 V
HP Smart Buy
HP Workstation Z440, Z640, Z840
