Honor 400 Pro - Lunar Grey
Quicklinx: J55JWS00 Mfr#: 5109BUSV
Colours:
£583.33 ex VAT
£699.99 inc VAT
Express delivery Order within the next 6 hours for delivery tomorrow
The HONOR 400 Pro 5G is a feature-packed smartphone designed for power users and photography lovers. Its 200MP AI Super Zoom Camera captures ultra-clear details, while AI Outpainting extends images beyond the frame and AI Eraser removes unwanted reflections. Create animated videos and moving photo collages with built-in AI tools and share seamlessly across devices.
It boasts a versatile camera setup with a 50MP telephoto, 12MP ultra-wide, and 50MP front camera, ideal for every angle. Despite its power, the phone is lightweight at 205g and just 8.1mm slim, with IP68/IP69 water and dust resistance.
The 6.7-inch AMOLED display delivers a smooth 120Hz refresh rate, 5000nits brightness, and AI eye care features like low blue light and motion sickness relief. With a 5300mAh battery, 100W SuperCharge, Snapdragon 8 Gen 3, and 12GB RAM + 512GB storage for everything you need
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: J55J 050856
Condition: Customer return - item has been used and shows signs of use /Slight scratches on screen ndoes not effect the vision on the screen
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  £306.97
Ref: J55J 050869
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  £330.58
Ref: J55J 050875
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Brand: Honor
Price Range Ex VAT: £500 - £750
Stock Status: Used Stock
