Honeywell Voyager 1400G Barcode Scanner
Quicklinx: BR3VWS00 Mfr#: 1400G2D-2USB
Type: Barcode scanner
Form Factor: Handheld
Max Paper Size: [N/A]
Interface: USB
Compatibility: PC
Hurry, only 1 left in stock!
£157.07 ex VAT
£188.48 inc VAT
2D bar code is becoming increasingly popular across a wide range of industries for a number of reasons. Some enterprises have a desire to capture large amounts of data, despite space constraints, while others are being required to read 2D bar code due to government regulations or supplier mandates. And an even larger group of enterprises simply have the desire to leverage emerging trends that require area-imaging technology, today or in the future, without needing to purchase additional scanning hardware.
Honeywell Voyager 1400g2D - barcode scanner
Barcode scanner - handheld - USB - decoded
Scan Field Width
35 cm
Scan Element Type
2D imager
Wired
18 cm x 4.3 cm x 6.6 cm
119 g
5-year warranty
Barcode
Interface Type
USB
Scan Field Width
35 cm
Scan Element Type
2D imager
Scan Mode
Single-pass
Skew (Degrees)
70
Pitch (Degrees)
60
Print Contrast Signal (PCS)
35%
Decode Capability
EAN/JAN, Code 93, Matrix 2 of 5, Code 39, NW-7, GS1 DataBar, QR code, Aztec code, MicroPDF417, Codabar, Code 128, Code 2 of 5, UPC, Interleaved 2 of 5, PDF417, Data Matrix, China Post, Codablock F, EAN-UCC Composite, MSI-3, Micro QR code, Code 93i, China Han Xin Code
TTL Decoding
Decoded
Wired
OK Notification
Beeper, LED indicator
Reduced Space Symbology (RSS), ESD (electrostatic discharge) safe
1 x USB - Type A
1 x USB cable - 1.5 m
FCC Class B certified, C-Tick, GS, ICES-003, RoHS, UL 60950-1 Second Edition, WEEE, cULus, IP42, IEC 60950-1 Second Edition
2 Watt
Electric Current Required
400 mA (operating), 90 mA (standby)
Software
Software Included
MasterMind
18 cm
4.3 cm
6.6 cm
119 g
Limited warranty - 5 years
0 - 95% (non-condensing)
Drop Specification
1.5 m to concrete
Interface: USB
Compatibility: PC
Brand: Honeywell
