Honeywell Hyperion 1300g Barcode Scanner
Quicklinx: B5F5WS00 Mfr#: 1300G-1USB
Type: Barcode scanner
Form Factor: Handheld
Max Paper Size: [N/A]
Interface: [N/A]
Compatibility: PC
£46.29 ex VAT
£55.54 inc VAT
Featuring an ideal balance of performance, durability and ergonomics, the Hyperion 1300g linear-imaging scanner provides years of hassle-free scanning, especially in scan-intensive or light industrial applications. Fast intuitive reading of 13 mil bar codes out to 18 inches (457 mm), as well as reading of high density bar codes as small as 3 mil are both enabled in a single device, eliminating the need to purchase specialty scanners.
  • Superior hand-held scanning
    Increases throughput by offering intuitive and aggressive hand-held scanning performance.
  • Highly versatile
    Eliminates the need to purchase specialty scanners by providing the ability to read out to 18 inches (457 mm) on 13 mil bar codes, as well as reading of high density bar codes as small as 3 mil in a single device.
  • Class-leading durability
    Increases up time and reduces service costs with a reliable design that utilizes no moving parts and full impact resistant bumpers.
  • Comfortable, ergonomic design
    Ensures operator comfort and productivity with a gun-shaped form factor optimized for intensive hand-held scanning.
  • Automatic interface detection
    Supports all popular interfaces in one device, replacing the time consuming process of scanning programming bar codes with automatic interface detection and configuration.
  • Remote MasterMind scanner management software
    Provides a quick and convenient solution for IT administrators seeking to manage all scanners within their network from a single remote location.
Honeywell Hyperion 1300g - barcode scanner
Barcode scanner - handheld - USB - decoded
White
Minimum Bar Width
3 mil
Scan Field Width
660 mm
Scan Element Type
Linear imager
Scan Speed
270 scan / sec
Wired
7.9 cm x 11.2 cm x 15 cm
160 g
5-year warranty
White
Barcode
Interface Type
USB
Minimum Bar Width
3 mil
Scan Field Width
660 mm
Scan Element Type
Linear imager
Scan Mode
Single-pass
Scan Speed
270 scan / sec
Skew (Degrees)
65
Pitch (Degrees)
65
Print Contrast Signal (PCS)
20%
Decode Capability
EAN/JAN, Code 93, Matrix 2 of 5, Code 39, NW-7, GS1 DataBar, Telepen, Code 32, Codabar, Code 128, Code 11, Code 2 of 5, UPC, Interleaved 2 of 5, MSI-Plessey, China Post, Trioptic Code, EAN-UCC Composite, Code 93i
TTL Decoding
Decoded
Wired
OK Notification
Beeper, LED indicator
1 x USB
1 x USB cable
UL, FCC Part 15 B, WEEE
Software
Software Included
MasterMind
7.9 cm
11.2 cm
15 cm
160 g
Limited warranty - 5 years
50 °C
0 - 95% (non-condensing)
Drop Specification
1.5 m
Interface: [N/A]
Compatibility: PC
Brand: Honeywell
