Honeywell C1 Wi-Fi Security Camera
Always know what's going on at home.
The home security camera that works around the clock, wherever you are.
The C1 Wi-Fi Security Camera means you never need to worry about missing an event when you’re not there. It’s always on when you’re away from home — recording events as they happen and notifying you of any movement or recognised sounds. So you can see it, and stop it.
Capture every moment
Our camera works round the clock to capture every moment in high definition, so you can watch a crystal-clear live stream of what’s happening at home – wherever you are. And thanks to Honeywell’s smart trusted technology, it starts recording five seconds before an event happens so you’ll never miss a moment again.
Unrivalled peace of mind
Built by a global leader in home security, the C1 sends rapid notifications to your smart device if something unusual happens. So you can see it and stop it.
Super-simple to install and use
Designed with you in mind with flexible mounting options, our camera is easy to install and use. Just plug it in and set up via the intuitive Honeywell Home app and you’ll be up and running in minutes.
Intelligent Sound Detection
The C1 recognises specific noises, like existing* smoke or carbon monoxide alarms, and sends a rapid push notification or email to your smart device. It’s the easy way to know if these critical alarms are sounding when you’re away.
High Definition wide-angle view
The C1 gives you a perfect view of your home. So no fuzzy screen. No blurry shapes. No pan-and-tilt. Just a powerful 135° wide-angle live video stream with 5x digital zoom that shows you what’s happening in 720p high definition.
Night Vision up to 5m
Security and safety don’t stop when the sun goes down. Our camera’s special night vision mode helps you keep an eye on things up to five metres away, so you can enjoy superior security by capturing every moment around the clock.
Two Adjustable Alert Zones
None of us likes false alerts, but with two adjustable alert zones, you can choose to ignore background motion, like ceiling fans. Alternatively, you can use them to increase sensitivity around important areas like doors and windows.
Two-way audio puts you in touch
You might be out of sight but you can still stay in touch with family members – and those mischievous pets – with the handy two-way audio function. So as well as watching what’s happening via live stream, you can also speak to whoever’s at home.
Free Secure cloud and SD Card storage
Free cloud storage lets you stream and download clips from the past 24 hours, while the free 8GB SD card acts as back-up when there’s no Wi-Fi, so you can continue to monitor securely – with all recordings protected by 256-bit advanced encryption.
Geofencing when you're Home or Away
The Honeywell Home app uses geofencing technology to track your location and enable home and away modes. So it automatically turns the camera on when you leave the house, then off again when you come home – meaning it’s always in tune with your movements.
Easy to set up
There’s no tricky wiring to worry about, just plug it in. Your camera can be wall-mounted or freestanding for greater flexibility. Plus the Honeyell Home app will guide you through the easy set-up process.
How to setup:
Get the app - The Honeywell Home app is available for Android and Apple devices. It’s easy to use – simply create an account and each time you log in, you can control your C1 Wi-Fi Security Camera from anywhere, anytime.
Connect your camera - Getting started only takes a few minutes. Just plug your camera in and switch it on — the app will detect it and guide you through the simple set-up process.
Take control - That’s it, you’re ready. Wherever you are, you can now use your smartphone or tablet to monitor your home and manage your home security. As soon as you receive an alert, the camera intelligently shows you the recorded video footage so you can take action.
Peace of mind - As well as superior safety and quality build, your camera is protected by a two-year guarantee. For further peace of mind, adding multiple cameras lets you watch over your whole home – and they all work perfectly in tune with the same Honeywell Home app.
Honeywell Home App
Stay in control of your home comforts, even when you're away.
One app for your connected home:
We’re saying "goodbye" to the Honeywell Lyric app and "hello" to the Honeywell Home app, to make room for big improvements.The Honeywell Home app has more features, like the usability upgrades you’ve asked for, one-touch dashboard and improved geofence. It provides a better experience for you by bringing our T6 thermostats, security and awareness products together under one roof – onto a single app on your mobile device.
With the Honeywell Home app, you can take control of your home comforts and always know what's going on at home, at the touch of a button. Available for Android and iOS devices, it puts you in charge of your smart home devices, wherever you are.
One Touch Dashboard - Conveniently verify the status and control your connected devices from one place. Change your temperature setting, view the status and last image taken by your camera, or watch the relative humidity of your water leak detector.
Simple Setup - Getting started is quick and easy as the app guides you through each simple step. It’s equally easy to use, with pre-configured scheduling and a wide choice of settings.
Family Access - Conveniently verify the status and control your connected devices from one place. Change your temperature setting, view the status and last image taken by your camera, or watch the relative humidity of your water leak detector.
Location Based Control (Geofencing) - Our geofencing technology just got smarter: More accurate location awareness means more precise performance. Using geofencing technology, the Honeywell Home app keeps track of your location and knows when you’re returning - adapting your smart home technology to suit your needs. Your thermostat will automatically set to your preferred temperature, ensuring your home is comfy and cosy on your arrival. Home or away modes will also be enabled on your C1 and C2 Security Cameras depending on your location, automatically turning the camera on when you leave the house, then off when you come home. So it’s always in tune with your movements.
Programmable - The Honeywell Home app is as flexible as you are. So you can program your comforts for the week ahead — and adjust them easily if your plans change suddenly.
Always know what's going on at home - Our indoor security camera lets you watch what’s happening at home, so if something happens when you’re not there, you can take action.
- Honeywell C1 - Indoor WiFi Security Camera
- WiFi Security Camera
- Audio
- Yes: two-way audio capability
- 11.2 cm
- 113 g
- Connectivity Technology
- Wireless
- Camera
- Colour - Day&Night
- Video Modes
- 720p
- WiFi
- Motion sensor, sound sensor
- Network surveillance camera
- Audio Support
- Wireless
- 11.2 cm
- 113 g
Camera
- Colour - Day&Night - fixed
- Video Modes
- 720p
- Digital Zoom
- 5
- Network Interface
- WiFi
