Hive Thermostat Stand
Quicklinx: G40JWS00 Mfr#: UK7000730
The Hive Active Thermostat Stand allows you to keep your thermostat safe and firmly in place anywhere in your home. The sleek modern design fits in with any home and the weighted and non-slip base will keep it safe wherever you decide to use it. Compatible with V2 and V3 Hive thermostats: SLT3c, SLT3 and SLT3b. Can't be used with Hive mini (SLT6), V2 Active Wired thermostat (SLT5) and Hive thermostat V1 (SLT2).
Move your thermostat around your home.
Stand your thermostat anywhere
If you want your thermostat to be freestanding so you can move it around your home, our Thermostat Stand is ideal.
Designed to stand out
With a solid zinc base and black chrome-plated finish, our thermostat stand fits anywhere in your home.
Hive - thermostat stand - black chrome
Thermostat stand
Black chrome
1-year warranty
9.57 cm x 9.87 cm x 10.16 cm
Thermostat stand
Black chrome
Warranty
1-year warranty
9.57 cm
9.87 cm
10.16 cm
200 g
