Hive Active Light - Cool to Warm White - Screw fitting
Match the lighting to your mood. Adjust our Cool to Warm White smart bulb from your smartphone.
- Just replace your existing light bulb with a Hive Active Light and pair with your Hive Hub.
- Set schedules and pick your brightness and warmth to match the moment.
- Save energy by controlling your lights remotely. A great way to reduce your energy bills.
Stay focused for longer
Stay energised when you're working late by tuning your Hive Active Light to a cooler shade of white.
Jetting off into the sun?
Schedule your Hive Active Light to come on every evening to give you the peace of mind that it looks like somebody's home.
Come home to a brighter welcome
Flick your lights on from outside when you reach the front door.
- Hive Active Light - LED light bulb - E27 - 9 W - cool daylight/warm white light - 2700-6500 K
- Light Source Type
- LED light bulb
- Socket Type
- E27
- Wattage
- 9 W
- Colour of Illumination
- Cool daylight/warm white light
- Colour Temperature
- 2700-6500 K
- Beam Angle
- 240 degree(s)
- Dimmable
- Platform
- Hive
Light Source
- LED light bulb
- Socket Type
- E27
- Wattage
- 9 W
- 2700-6500 K
- Beam Angle
- 240 degree(s)
- Dimmable
- Lifetime
- 25000 hours
- Android compatible, iOS compatible, light scheduling, shadow-free
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Hub Compatibility
- Hive Hub
- Platform
- Hive
- 60 mm
- 120 mm
- 119 g
- Shipping Dimensions (WxDxH) / Weight
- 71 mm x 71 mm x 136 mm
