Hive Light Colour Changing E27 Smart Bulb - Triple Pack
Quicklinx: FYDCWS00 Mfr#: UK7000846-3PACK
A colour changing smart light bulb you can control from anywhere (requires Hive Hub sold separately).
The light bulb smart enough to match any mood
Our colour-changing smart bulb will help you match the lighting to your mood with more colours than you can imagine – all from your smartphone.
Save energy, save money
Our long-lasting smart bulbs are rated A+ for energy efficiency, and by controlling them remotely you can make sure they're not left on.
Get the lighting just right from wherever you are
Manage your lighting via the Hive app on your phone, so it’s just how you like it, just when you need it.
Lighting how you like it
Personalise the lighting for every room and set schedules so your lights turn on and off automatically.
Set them up in seconds
Just replace your existing light bulbs with Hive Light bulbs and pair them with your Hive Hub (sold separately). So you can spend more time doing the things you love.
Turn them off together
Group your Hive Lights so that you can control all of them together. With one tap on the app you can turn all your lights on or off in one go, from anywhere.
Make it look like you’re in when you’re out
Hive Lights are brilliant for giving you a little extra peace of mind while you're away. Make it seem like someone’s home by setting lighting schedules. Or with Mimic mode, get your lights to turn on and off in a varied pattern.
Set up Hive Actions
Hive Lights can also connect to other Hive devices like sensors through your Hive app. So your lights can turn on automatically when you walk through the front door.
Manage them with your voice
All Hive Lights work with both Amazon Alexa and Google Assistant so anyone can use their voice to turn all the lights on or off together. Perfect for when your hands are full and you can’t get to the Hive app.
