Hive Active Light - Colour Changing - Screw fitting
Match your lighting to your moods with our colour-changing smart bulb, in 16 million colours.
- Just replace your existing light bulb with a Hive Active Light and pair with your Hive Hub.
- Set schedules and pick your brightness and colour to match the moment.
- Save energy by controlling your lights remotely. A great way to reduce your energy bills.
Get the party started
Jazz up the colour of your home using our colour-changing smart bulb.
Make time in the morning
Turn your lights off from your phone after you've left for work.
Come home to a brighter welcome
Flick your lights on from outside when you reach the front door.
- Hive Active Light - LED light bulb - E27 - 9.5 W - RGB/white light - 2700-6500 K
- Light Source Type
- LED light bulb
- Socket Type
- E27
- Wattage
- 9.5 W
- Energy Efficiency Class
- A+
- Colour of Illumination
- RGB/white light
- Colour Temperature
- 2700-6500 K
- Luminous Power
- 806 lumens
- Beam Angle
- 240 degree(s)
- Dimmable
- Intelligent Assistant
- Google Assistant, Alexa - indirect
- Platform
- Hive
- Communications Technology
- Zigbee
- Voltage Required
- AC 220 - 240 V
Light Source
- LED light bulb
- Socket Type
- E27
- Wattage
- 9.5 W
- A+
- RGB/white light
- 2700-6500 K
- Luminous Power
- 806 lumens
- Luminous Efficacy
- 89 lm/W
- Beam Angle
- 240 degree(s)
- Dimmable
- Lifetime
- 25000 hours
- ZigBee technology, Android compatible, iOS compatible, voice control, remote controlled, light scheduling, screw mounting base
Power Requirements
- Voltage Required
- AC 220 - 240 V
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Hub Compatibility
- Hive Hub
- Platform
- Hive
- Zigbee
- Voice Controlled
- Indirect
- Package
- Box
- Diameter
- 60 mm
- Length
- 120 mm
- 116 g
- Shipping Dimensions (WxDxH) / Weight
- 71 mm x 71 mm x 136 mm / 163 g
