Hive Hub - Wireless Smart Home Hub Unit
Quicklinx: D2CSWS00 Mfr#: HAH2HUBRETAIL
48 In Stock
£74.99 ex VAT
£89.98 inc VAT
For a home that always knows what you want
The essential Hive Hub is the brains of your smart home. It connects all your devices to the internet – and to each other. So you can control everything straight from your smartphone.
Saving money starts here
The Hive Hub makes all our smart features possible. By linking your Hive tech together, you can create energy-saving actions and access handy insights that make it easy to save money.
Quick to install and easy to use
Just plug it straight into your broadband router, follow the instructions on the Hive app and pair it with your Hive devices. Then you’re ready to start saving energy and lowering those bills!
The heart of your smart home
The clever Hub stores all your schedules and keeps all your data safe. So you can get back to enjoying a seamlessly connected home.
Hive Hub - central controller
Central controller
9.61 cm x 2.73 cm x 9.66 cm
Central controller
9.61 cm
2.73 cm
9.66 cm
114 g
