Hitachi PJ-TX300 HD Ready Projector
Customer rating: 5.0* (Write a review)
Quicklinx: 49MLWS00 Mfr#: PJ-TX300
  • High-Definition Multimedia Interface (HDMI)
The PJ-TX300 CINE MASTER projector is sleek, compact and powerful with an amazing 10,000: 1 contrast ratio to create a breathtaking cinema experience in your own home.
This top of the range Home Cinema Projector is HD ready and uses a Super Focus ED x 4 lens and 10 bit Digital Video Processing to give superb picture quality. It can be connected easily to a wide variety of inputs from digital TV receiver to PC.
With horizontal and vertical lens shift to ensure a perfectly aligned picture from wherever you place the projector.
Hitachi Cine Master PJ-TX300 - LCD projector
LCD projector - 720p
Brightness
1200 lumens
Contrast Ratio
10000:1
Resolution
1280 x 720
Native Aspect Ratio
16:9
Colour Support
1.07 billion colours
Lens Shift Direction
Horizontal, vertical
Bulb type
UHB 150 Watt
Video Input
RGB, S-Video, composite video, component video (NTSC, SECAM, PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, PAL 60, PAL-D, PAL-H)
Digital Video Standard
AC 120/230 V
220 Watt
34 cm x 29.8 cm x 11.3 cm
4.7 kg
Projector
Brightness
1200 lumens
Brightness (Reduced)
960 lumens
Contrast Ratio
10000:1
Image Size
76 cm - 762 cm
Projection Distance
0.8 m - 13.8 m
Resolution
1280 x 720
Native Aspect Ratio
16:9
Colour Support
Max Sync Rate (V x H)
120 Hz x 64 kHz
Bulb type
UHB 150 Watt
Controls & Adjustments
H/V position, gamma correction, keystone correction, phase, H-size, lens shift dial (horizontal), lens shift dial (vertical)
OSD Languages
Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Japanese, Korean
Integrated de-interlacer (progressive scan)
Lens
Focus Type
Manual
Lens Aperture
F/1.7-2.4
Zoom Type
Manual
Keystone Correction Direction
Vertical
Lens Shift Type
Manual
Vertical Lens Shift
5:1 - 1:5
Horizontal Lens Shift
3:1 - 1:3
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, component video, composite video, S-Video
Input Device
External
1 x VGA - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x component video input - RCA x 3 , 1 x HDMI - 19 pin HDMI Type A , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management)
Wireless remote control
1 x component video cable
UL, TUV, cUL, DDC-1, DDC-2B, EN 60950
AC 120/230 V
220 Watt
34 cm
29.8 cm
11.3 cm
4.7 kg
Customer reviews
Write a review for the Hitachi PJ-TX300 HD Ready Projector here!
Outstanding HD projector
Reviewed by JFW. Review Posted 28/11/2006
OK so it's only 720p and not 1080p but for this money you really can't beat this projector. Great blacks and contract ratio is outstanding. Worth tinkering with the picture settings though to get the right picture for you, 'sports' setting excellent for HD gaming. Also very quiet compared to other AV projectors that I've used.
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
