Hitachi CP-X3020 Projector
Quicklinx: 7KKKWS00 Mfr#: CP-X3020
This Multi Purpose projector brings together the finest features for business and education. You'll find top-of-the range picture quality, security and networking, in a user-friendly package. Hitachi is dedicated to lowering costs and protecting the environment, so it also features longer-life parts and energy-saving settings.
  • 3LCD
    A sophisticated technology that utilizes 3 chips to deliver vibrant, true-to-life and consistent images for the most demanding audiences.
  • Hybrid Filter
    The Hybrid Filter lasts for more than 4000 hours, ten times longer than conventional filters. This extension in maintenance intervals reduces the overall cost of ownership significantly.
  • Security features
    Advanced security features include Multi-Level PIN-Lock, Transition Detector, steel security bar, Kensington Lock and prominent security labels.
  • Blackboard / whiteboard mode
    Projecting onto colored or shiny backgrounds can make images appear either dull or uncomfortably bright. This mode ensures optimal brightness whether the screen is black, green or shiny white.
  • Low TCO
    Significantly extended maintenance intervals resulting from long-life parts reduces the total cost of ownership.
  • Template function
    This Hitachi feature allows you to project different patterns of lines and grids onto a whiteboard, blackboard or flip chart, making writing and drawing easier.
  • Daytime mode
    It can be harder to see a projected picture when the sun is shining brightly. Projections are always vivid and colorful in a bright environment with daytime mode.
  • Ultra quiet
    With a low noise level of 29dB, the internal fan is one of the quietest in its class. The audience will hear the presenter, not the operating noise of the projector.
  • My Button
    Assign custom functions or common tasks to a programmable button on your remote control.
  • Audio pass through
    When all you need is sound and not pictures, this convenient feature lets you hear the projector's speakers whilst the rest is on stand-by - helping to preserve lamp life.
  • Progressive scan
    Typically with moving images, each frame of video is shown in two halves - odd lines and even lines. Progressive Scan enables every line of a video frame to be displayed simultaneously resulting in crisp, smooth motion and reduced flicker and judder.
Hitachi CP-X3020 - LCD projector - portable
LCD projector
Built-in Devices
Speaker
Brightness
3200 lumens
Contrast Ratio
500:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Bulb type
UHB 200 Watt
Video Input
RGB, S-Video, composite video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43)
Video Modes
480p, 480i, 576i, 576p, 1080/60i, 1080/50i, 1080/50p, 1080/60p, 750/50p, 750/60p
Video Output
RGB
Speakers
Speaker(s) - integrated
AC 120/230 V
30.6 cm x 22.1 cm x 7.7 cm
2.2 kg
LCD projector
Built-in Devices
Speaker
Projector
Brightness
3200 lumens
Contrast Ratio
500:1
Resolution
XGA - XGA (1024 x 768)
Native Aspect Ratio
4:3
Display Format
786,432 pixels (1,024 x 768) x 3
Bulb type
UHB 200 Watt
Controls & Adjustments
Keystone correction
Blackboard Mode, Closed Caption, Daytime Mode, Whiteboard Mode, input source naming
Lens
Zoom Factor
1.2x
Keystone Correction Type
Digital
Keystone Correction Direction
Vertical
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, composite video, S-Video
Video Modes
Video Output
Analogue Video Signal
RGB
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
1 Watt
Speakers
1 x mixed channel
Input Device
External
1 x serial RS-232C - 9 pin D-Sub (DB-9) , 2 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x USB - 4 pin USB Type B (management) , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN
Lens cover, wireless remote control
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), security label
UL, CISPR 22 Class B, cUL, FCC Part 15 B, RoHS, GOST-R
AC 120/230 V
30.6 cm
22.1 cm
7.7 cm
2.2 kg
35 °C
28 dB
