Hitachi's CP-AX2505 ultra short throw LCD projector is ideally suited for producing large images in limited spaces. It provides vibrant image quality with cost-effective operation. A suite of advanced features normally found only on higher end models includes 2 HDMI ports, High Dynamic Contrast Range (HDCR), and Hitachi's original technology Accentualizer that allows the projected image to appear more real by enhancing sharpness, gloss and shade. Along with its light weight and compact design, the CP-AX2505 offers Hitachi's most appreciated installation feature, "Perfect Fit", allowing time saving and ease of installation. As with all Hitachi projectors, you can expect vibrant image quality, cost-efficient operation, and long-lasting reliability. Plus, Hitachi's Intelligent Eco and Saver Modes with ImageCare combines optimal picture performance with energy savings for a lower total cost of ownership.
Accentualizer
Hitachi original technology makes pictures took more real by enhancing sharpness, gloss and shade to make pictures as dear as pictures on a flat-panel device. You can also adjust the effects by three levels according to your surroundings so that the colors of projected images are the actual colors of the objects they represent. -
HDCR (High Dynamic Contrast Range)
When average projectors are used In bright rooms, the darker colors of an image deteriorate and images become unclear. Using this function blurred images caused by room lighting a outside light sources are corrected, and an effect similar to increasing contrast occurs. Thts results in clear Images even in bright rooms. -
Cloning Function
Copy setting data from one projector to others of the same model via USB memory. Coloring not only saves almost ai PJ settings such as gamma and keystone via USB memory, it saves countless hours in setup and installation. -
ImageCare Technology
ImageCare is a lamp power control function that combines optimal picture performance with maximum energy savings by decreasing energy usage. Improving contrast ratio and lengthening lamp life. The result Is a tower total cost of ownership and decreased maintenance cost. -
Intelligent eco and saver modes
Automatically changes the brightness of the lamp according to the brightness level of the screen. Also, automatically changes the brightness of the lamp. If there is no change In the screen image. Using ImageCare technology, these features give optimal picture performance with maximum energy savings. -
Perfect Fit 2
Enables the user to adjust individual comers and sides independent of one another. Perfect Fit 2 provides vertical and horizontal digital correction of either barrel or pin cushion distortions. This feature helps correct geometric and complicated distortions. Perfect Fit 2 allows the projected image to fit correctly to the screen quickly and east/. -
Projector quick connection app for mobile devices
iOS and Android applications offers projector control and also provides the capability to display photos, document ties and web site contents. Available for iPad, iPhone and Android devices. Works over your LAN via your RJ-45 port or via an optional USBWLIIN wireless adapter. -
Input source naming
Users can name input sources In simple language instead of factory default names. -
Microphone input
A microphone can be used via the jack boated on the input panel. A tows for more dynamic presentations even in standby mode. -
Network control, maintenance and security
Embedded networking gives you the ability to manage and control multiple projectors over your LAN. Features Include scheduling of events, centralized reporting, image transfer and e-mail alerts for reactive and routine maintenance. -
PC-Less presentation
By using a USB memory stick or other storage device, you can use the projector without a computer. Menus are easy to see with a thumbnail desplay. Additionally there is also a slide show and video function. -
PIN Lock / MyScreen / MyText
PIN lock protection can limit projector users. MyScreen PIN tack keeps captured Images on the startup screen. Users can set any name logo to MyScreen. clearly identifying ownership. MyText provides the ability to write text on the startup screen such as modal name, serial number or location. -
PJ Messenger
PJMessenger function allows you to send and display text messages and auto alerts on your networked projectors. It is easy and efficient way to send announcements out to multiple units. -
Template function
Line templates in the projector menu can help when writing on a whiteboard. There are four types of line templates to choose from. -
Wireless presentation compatible
Connect the projector to a computer or your network using the optional USB wireless adapter (part number USBWLI IN). The adapter supports IEEE802.1 b/g and the latest 11n.
- Hitachi CP-AX2505 - 3LCD projector - LAN
- 3LCD projector
- Built-in Devices
- Speaker
- Brightness
- 2700 lumens
- Contrast Ratio
- 10000:1
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Colour Support
- 16.7 million colours
- Bulb type
- 225 Watt
- Bulb life cycle
- Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
- Video Input
- RGB, composite video, component video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43), LAN
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 330 Watt
- 37.6 cm x 36.1 cm x 13.7 cm
- 4.26 kg
- 3-year warranty
- 3LCD projector
- Built-in Devices
- Speaker
- Networking
- Ethernet
Projector
- Brightness
- 2700 lumens
- Contrast Ratio
- 10000:1
- Image Size
- 152 cm - 254 cm
- Projection Distance
- 0.38 m - 0.66 m
- Throw Ratio
- 0.2 - 0.3:1
- Resolution
- XGA - XGA (1024 x 768)
- 4:3
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 106 kHz
- Bulb type
- 225 Watt
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- Closed Caption, 3LCD Technology, 16:9 aspect ratio support, input source naming, 16:10 aspect ratio support, AMX Device Discovery, Perfect Fit 2, Template Function, PJMessenger, ImageCare Technology, Cloning Function, Intelligent Eco, High Dynamic Contrast Range (HDCR), Tabletop Presentation, Projector Quick Connection
Lens
- Lens Aperture
- F/1.8
- Keystone Correction Direction
- Horizontal, vertical
- Vertical Keystone Correction
- -5/ +5
- Horizontal Keystone Correction
- -5/ +5
Video Input
- TV System
- NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video
- Video Modes
- LAN and Wireless Image Transferring Protocols
- Wired LAN
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 16 Watt
- Speakers
- 1 x mixed channel
- 2 x HDMI - 19 pin HDMI Type A , 2 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x audio line-in - RCA x 2 , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x microphone input - mini-phone mono 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x network - RJ-45 , 2 x USB - 4 pin USB Type A , 1 x USB - 4 pin USB Type B , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management)
- Included Accessories
- Cable cover, 2 x AA batteries, wireless remote control, adapter cover
- Cables Included
- 1 x VGA cable
- Security Features
- PIN code
- FCC Class B certified, cUL, FCC Part 15 B, UL 60950-1
- Power Source
- AC
- Voltage Required
- 330 Watt
- Software Included
- Drivers & Utilities
- 37.6 cm
- 36.1 cm
- 13.7 cm
- 4.26 kg
- Limited warranty - parts and labour - 3 years
- 0 °C
- 40 °C
