Hitachi 320GB LifeStudio Mobile 2.5" 5400RPM USB2 Platinum
Quicklinx: 74CLWS00 Mfr#: 0S02703
The LifeStudio Mobile Plus external drive automatically finds and organizes photos, films, music and files into a stunning 3D wall so you can easily view all your content from one location, plus access and post photos to Facebook, Flickr and Picasa.
Automatic local and online backup provide two levels of reliable protection to help keep your digital content safe. And you can access your files from any computer or smartphone using an internet browser, or share with others by sending a web link.
More than an ordinary hard drive - this is the hard drive re-invented.
  • Portable design
    The WD LifeStudio Mobile external hard drive boasts a compact and portable 2.5" form factor, making it an ideal companion for users on-the-go. Its sleek design fits comfortably in the palm of your hand, ensuring you can carry your valuable data wherever you travel.
  • Seamless compatibility
    Designed to work effortlessly with both Mac and PC platforms, the WD LifeStudio Mobile external hard drive offers versatile compatibility. This ensures users can easily access, save, and share files across multiple devices without worrying about file format restrictions.
  • Efficient connectivity
    Equipped with a USB 2.0 interface, the WD LifeStudio Mobile provides reliable and efficient connectivity. This feature allows for quick and easy data transfer, ensuring your files are always accessible when you need them.
WD LifeStudio Mobile HLSMBEA3201AFB - hard drive - 320 GB - USB 2.0
Hard drive - external (portable)
320 GB
2.5"
USB 2.0
Data Transfer Rate
480 Mbps
Bus Powered by USB
Power Source
USB bus
Enclosure Colour
Platinum
8.4 cm x 7 cm x 13.4 cm
EMEA
320 GB
2.5"
USB 2.0
Bus Powered by USB
8.4 cm
7 cm
13.4 cm
Performance
Interface Transfer Rate
480 Mbps
Expansion & Connectivity
1 x USB 2.0
Compatible Bay
2.5"
Power Source
USB bus
Software Included
Drivers & Utilities, Hitachi Local Backup, Hitachi LifeStudio
Microsoft Windows Vista / XP / 7, Apple MacOS X 10.5 or later
USB cradle
1 x USB cable
FCC, RoHS
Enclosure Colour
Platinum
EMEA
5 °C
35 °C
20 - 80%
