Hitachi's CP-DX300 DLP projector represents the standard for classroom environments and versatility with high resolution XGA performance, an innovative feature set and overall value. The CP-DX300 incorporates 3,000 ANSI lumens light output and a 2500:1 contrast ratio for vibrant, bold images with deeper black levels and razor-sharp text. Performance versatility is enhanced by HDMI terminals which accommodate many types of AV devices. Plus, Hitachi's intelligent eco mode with ImageCare combines optimal picture performance with energy savings for a lower cost of ownership.
The light output specification measures the brightness of light output and with 3,000 ANSI lumens the result is bright, clear, true to life images with incredible detail. -
Contrast can be automatically controlled through an active iris to add depth perspective during both bright and dark scenes. -
HDMI input (HDCP)
Digital connectivity allows for highest image quality from your HD device. Compliancy with HDCP. -
Power saving standby mode
Power saving mode reduces the standby power consumption to less than 0.5 W. -
BrilliantColor
BrilliantColor technology is setting a standard in color performance. BrilliantColor offers color processing to enhance color performance for rich, vibrant and accurate colors. -
DLP technology
DLP technology was invented, developed and is owned by Texas Instruments. The DLP chip is a digital semiconductor that contains millions of microscopic mirrors. These projectors use DLP technology to project images with amazing quality. -
Easy maintenance
Easy maintenance is another attractive function, as the lamp door is on top of the model. -
Wall color correction
This feature corrects the color of images projected on surfaces that are not white to prevent color differences between the source and projections. Five wall color modes include light yellow, light green, blue, black board and pink. -
3D capable
Discover the teaching advantages of 3D! This DLP projector offers the latest trend for the classroom with 3D viewing. It will engage your students and can improve the learning process.
- Hitachi CP-DX300 - DLP projector - portable - 3D
- DLP projector
- 3D Capable
- Built-in Devices
- Speaker
- Brightness
- 3000 ANSI lumens
- Contrast Ratio
- 2500:1
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Colour Support
- 1.07 billion colours
- Bulb type
- UHP 196 Watt
- Bulb life cycle
- Up to 4500 hour(s) - normal mode , Up to 6000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video, component video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43)
- Video Modes
- 480p, 480i, 525i, 525p, 625i, 576i, 1080/60i, 720/60p, 1080/50i, 720/50p, 750p, 1080/50p, 1080/60p, 1125i, 1125p
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 250 Watt
- 26.5 cm x 22.3 cm x 8.15 cm
- 2.2 kg
- 3-year warranty
- DLP projector
- 3D Capable
- Built-in Devices
- Speaker
Projector
- Brightness
- 3000 ANSI lumens
- Brightness (Reduced)
- 2600 ANSI lumens
- Contrast Ratio
- 2500:1
- Image Size
- 76 cm - 762 cm
- Projection Distance
- 1 m - 12 m
- Throw Ratio
- 1.86 - 2.04:1
- Resolution
- XGA - XGA (1024 x 768)
- 4:3
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 102 kHz
- Bulb type
- UHP 196 Watt
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- OSD Languages
- Hindi, Hungarian, Czech, Indonesian, Thai, Chinese (traditional), Vietnamese, Brazilian Portuguese, English, German, French, Italian, Polish, Swedish, Russian, Spanish, Greek, Turkish, Arabic, Japanese, Korean
- sRGB colour profile, freeze frame, Blackboard Mode, Auto Input Search, Closed Caption, High-bandwidth Digital Content Protection System (HDCP), wall colour correction, BrilliantColor, DLP 3D Ready, 16:9 aspect ratio support, Game mode, upgradable firmware, ImageCare Technology, Auto Power Off, Mirror Reverse image, Auto Eco Mode
Lens
- Focus Type
- Manual
- Zoom Type
- Manual
- Zoom Factor
- 1.1x
- Keystone Correction Type
- Digital
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -30 / +30
Video Input
- TV System
- NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video
- Video Modes
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 2 Watt
- Speakers
- 1 x mixed channel
- 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x HDMI input - 19 pin HDMI Type A , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 1 x USB - 4 pin USB Type B (management)
- Included Accessories
- Wireless remote control
- Cables Included
- 1 x VGA cable
- Security Features
- Security lock slot (cable lock sold separately), password protection, security bar
- TUV GS, cUL, DDC-2B, EN 61000-3-2, EN55022, EN 61000-3-3, EN55024, FCC Part 15 B, RoHS, UL 60950-1, EN 60950-1, WEEE, GOST-R, Energy-Related Products (ErP) Lot 6
- Power Source
- AC
- Voltage Required
- 250 Watt
- Power Consumption Stand by
- 0.5 Watt
- 26.5 cm
- 22.3 cm
- 8.15 cm
- 2.2 kg
- Limited warranty - 3 years , Limited warranty - lamp - 6 months
- 0 °C
- 35 °C
- Sound Emission
- 35 dB
- Sound Emission (Economic Mode)
- 31 dB
