- HD Resolution Watch your favorite movies, TV shows, games, and more in crisp HD resolution, and relish in the vivid color range and from a wide angle. Practically all of today’s content is available in HD, making it the ideal companion for casually viewing the full array of digital content for an undeniably enjoyable TV experience.
- High Contrast With High Contrast displays, highlights look brighter, blacks are deeper, and the colors are more vibrant. Improved contrast means dark parts of the screen are truly dark, while light areas are accurately lit. Feel the difference with contrast that’s immediately visible on the edge between light and dark for a satisfying TV experience.
- Natural Colour Enhancer The Natural Color Enhancer aims to bridge the gap between digital screen and reality, by optimizing the color reproduction in real time, able to pick up on even the smallest differences. Whether you’re watching your favorite shows, documentaries, or movies, you’re sure to enjoy your time with colors the way they were meant to be seen.
- Noise Reduction The smart Noise Reduction feature is the optimal solution for combating grainy video. The TV is equipped to analyze the input signal and automatically detects, isolates, and reduces noise on screen to leave you with a crisp image. Enjoy your favorite shows and movies regardless of their original quality.
- Share to TV The Share-to-TV function lets you bypass this issue with ease and grace. Share content from your other devices directly to your screen. Use "Screen Sharing" to mirror your device on your TV, or the "Content Sharing" option, which lets you continue to use your device while only sharing specific media on the big screen for everyone to enjoy.
Display quality
The Hisense 32A4NTUK features a 720p resolution with a 3000:1 contrast ratio, ensuring vibrant colors and deep blacks for an enhanced viewing experience. -
Diverse entertainment options
This Smart TV supports a range of Internet streaming services, including Netflix, YouTube, and Prime Video, providing access to a library of content. -
Sound capabilities
With 12 watts of total output power and support for DTS-HD and Dolby Audio, the audio system delivers immersive sound that complements the visual experience. -
Versatile connectivity
The TV is equipped with multiple HDMI and USB ports, along with LAN and Wi-Fi connectivity, allowing for integration with various devices. -
User-friendly features
The interface includes web browsing functionality and a range of applications, making it easy to navigate and enjoy your favorite multimedia content.
- Hisense 32A4NTUK A4N Series - 32" LED-backlit LCD TV - HD
- Product Type
- LED-backlit LCD TV - Smart TV
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/1856656
- Diagonal Class
- 32"
- Black
- Platform
- VIDAA
- Resolution
- 1366 x 768
- Display Format
- 720p
- Frame Rate & Enhancement Technology
- 60 Hz Refresh Rate, 50 Hz Refresh Rate
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- Connectivity
- Wi-Fi, LAN
- LCD Backlight Technology
- Direct LED - full array
- Image Aspect Ratio
- 16:9
- Digital TV Tuner
- DVB-C, DVB-S, DVB-S2, DVB-T, DVB-T2
- Internet Streaming Services
- Netflix, YouTube, Deezer, AccuWeather, NBA, Red Bull TV, Plex, Hungama play, Toon Goggles, Game Center, Rakuten TV, DAZN, Prime Video, Youtube Kids, Disney+, Apple TV+, Kidoodle, Sweet.TV, UEFA TV, EON, FITE, FIFA+, RLAXX, VIDAA Free, Tet+
- Picture Enhancements
- MPEG Noise Reduction, 3D Digital Comb Filter, Mosquito Noise Reduction
- Sound Effects
- DTS Virtual:X
- USB
- 2 ports
- Included Accessories
- Remote control
- Voltage
- AC 100-240 V
- Energy Class
- Class F
- Power Consumption Stand by
- 0.5 Watt
- Dimensions (WxDxH) - without stand
- 72.6 cm x 8.5 cm x 43 cm
- Product Type
- Energy Class
- Class F
- Power Consumption (Max)
- 65 Watt
- Power Consumption SDR (On mode)
- 27 kWh/1000h
- Diagonal Class
- 32"
- Series
- A4N Series
- Platform
- VIDAA
- TV Tuner Presence
- Extended PVR
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- Modes
- Game mode, AI sports mode
- Dimensions
- Without stand
- 72.6 cm
- 8.5 cm
- 43 cm
- Enclosure Colour
- Black
Display
- Resolution
- 1366 x 768
- Display Format
- 720p
- 16:9
- Direct LED
- Image Contrast Ratio
- 3000:1
- Brightness
- 200 cd/m²
- Viewing Angle
- 178 degrees
- Response Time
- 8 ms
- Time-shift, VIDAA Art
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Stand Colour
- Black
- Flat Panel Mount Interface
- 100 x 200 mm
- VESA Compatibility
TV Tuner
- Conditional Access
- Common Interface Plus (CI+) slot
Digital TV Tuner
- Digital TV Tuner
Video Features
- Parental Channel Lock
Media Player
- Supported Video Formats
- MPEG-4, AVI, MKV, MOV, VOB, FLV, WebM, MPG, MPEG
- Supported Audio Formats
- MP3, WMA, WAV, AAC, FLAC (Free Lossless Audio Codec), MP2, MP4
- Supported Pictures Formats
- BMP, GIF, PNG, JPEG
- USB Port
- USB Ports Qty
- 2
Remote Control
- Remote control
- Voice control
Audio System
- Digital Audio Format
- DTS-HD digital output, Dolby Audio
- Sound Effects
- DTS Virtual:X
- Equaliser
- Output Power / Total
- 12 Watt
- Audio Return Channel (ARC)
- Speakers
- 2 x main channel speaker - 6 Watt
Network & Internet Multimedia
- Functionality
- WEB browsing, Internet video playback
- Connectivity
- Wi-Fi, LAN
- LAN Protocol
- Ethernet
- Wi-Fi Protocol
- 802.11b, 802.11g, 802.11n
- Connect & Share
- Screen Share, Sound Share
- Application Store
- VIDAA Store
- Connector Type
- 2 x HDMI , 2 x USB 2.0 , SPDIF output , Headphones , LAN
- Power Device
- Power supply
- Input Voltage
- AC 100-240 V
- 0.5 Watt
- Auto On/Off
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 72.6 cm x 8.5 cm x 43 cm , Panel with stand - 72.6 cm x 18.6 cm x 47.9 cm x 3.8 kg , Dimensions between support feet - 68.8 cm
- Width (Shipping)
- 81.1 cm
- Depth (Shipping)
- 12.2 cm
- Height (Shipping)
- 72.6 cm
- Weight (Shipping)
- 5.601 kg
