One-third more capacity and 23% lower energy consumption. Available today. That's the power of helium. Delivering the industry's leading capacity at 8TB, Ultrastar He8 is based on the widely accepted and proven HelioSeal platform. HelioSeal technology replaces air with helium inside the drive, reducing air turbulence and enabling 7Stac, a seven-disk design in a traditional 3.5-inch form factor. Ultrastar He8 goes beyond what any air-based HDD can do and seamlessly integrates into virtually any mainstream enterprise environment. Cooler and quieter with industry-leading power efficiency (Watts/TB) and no-compromise performance, the Ultrastar He8 lays the foundation for future growth in massive scale-out environments.
Volume is expanding, operating costs are rising while budgets remain flat. Lowering the total cost of ownership (TCO) has become the focus of data center architects. Ultrastar He8 provides the best TCO value proposition and delivers greater storage efficiency with breakthroughs in capacity, power efficiency and best-in-class performance. He8 offers a 12Gb/s SAS (6Gb/s SATA) interface for easy integration into high performance data centers. Features like Rebuild Assist dramatically reduce RAID rebuild times and maintain system performance during the rebuild process.
Compliance and privacy requirements drive the need for increased data security. Ultrastar He8 offers security and encryption options to protect data from unauthorized use. Instant Secure Erase (ISE) models expedite drive redeployment and retirement. Encryption models protect data with hardware-based encryption, including a Trusted Computing Group (TCG) option with FIPS 140-2 certification, Level 2. The Ultrastar He8 extends HGST's long-standing tradition of reliability leadership with a 2M-hour MTBF rating. HGSTs drive reliability and security options also help lower data center TCO.
HelioSeal delivers twice the capacity using one-quarter less power
One-third more capacity and 23% lower energy consumption. Available today. That's the power of helium. Delivering the industry's leading capacity at 8TB, Ultrastar He8 is based on the widely accepted and proven HelioSeal platform. HelioSeal technology replaces air with helium inside the drive, reducing air turbulence and enabling 7Stac, a seven-disk design in a traditional 3.5-inch form factor. Ultrastar He8 goes beyond what any air-based HDD can do and seamlessly integrates into virtually any mainstream enterprise environment. Cooler and quieter with industry-leading power efficiency (Watts/TB) and no-compromise performance, the Ultrastar He8 lays the foundation for future growth in massive scale-out environments. -
TCOptimized - increasing storage efficiency to drive down data center TCO
Volume is expanding, operating costs are rising while budgets remain flat. Lowering the total cost of ownership (TCO) has become the focus of data center architects. Ultrastar He8 provides the best TCO value proposition and delivers greater storage efficiency with breakthroughs in capacity, power efficiency and best-in-class performance. He8 offers a 12Gb/s SAS (6Gb/s SATA) interface for easy integration into high performance data centers. Features like Rebuild Assist dramatically reduce RAID rebuild times and maintain system performance during the rebuild process. -
Data security with industry-leading quality and reliability
- WD Ultrastar He8 HUH728080ALE600 - hard drive - 8 TB - SATA 6Gb/s
- Hard drive - internal
- Capacity
- 8 TB
- Form Factor
- 3.5" x 1/3H
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 128 MB
- Spindle Speed
- 7200 rpm
- Rotational Vibration Safeguard (RVS), Advanced Format technology, 7Stac, TCOptimized, 24x7 continuous operation, Instant Secure Erase (ISE), media caching technology, HelioSeal 2, Rebuild Assist mode
- 101.6 mm x 147 mm x 26.1 mm
- 650 g
- Microsoft Certification
- Compatible with Windows 7
- 5-year warranty
- Capacity
- 8 TB
- Form Factor
- 3.5" x 1/3H
- Interface
- SATA 6Gb/s
- Buffer Size
- 128 MB
- Bytes per Sector
- 512
- 101.6 mm
- 147 mm
- 26.1 mm
- 650 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 205 MBps
- Seek Time
- 8.5 ms (average)
- Average Latency
- 4.16 ms
- Spindle Speed
- 7200 rpm
Reliability
- MTBF
- 2,000,000 hours
- 24x7 Operation
- Non-Recoverable Errors
- 1 per 10^15
- Load / Unload Cycles
- 600,000
Expansion & Connectivity
- 1 x SATA 6 Gb/s - 7 pin Serial ATA
- Compatible Bay
- 3.5" x 1/3H
- Power Consumption
- 5.1 Watt (low power idle) , 7.4 Watt (active)
- EcoTrac
- Limited warranty - 5 years
- 5 °C
- 60 °C
- Shock Tolerance (operating)
- 70 g @ 2 ms half-sine pulse
- Shock Tolerance (non-operating)
- 300 g @ 1 ms half-sine pulse
- Vibration Tolerance (operating)
- 0.67 g @ 5-500 Hz
- Vibration Tolerance (non-operating)
- 1.04 g @ 5-500 Hz
