HGST Ultrastar 7K6000 HUS726060ALE610 Hard Drive 6TB SATA 6Gb/s 3.5" 7200rpm
Quicklinx: C6C6WS00 Mfr#: 0F23001
Corporate and cloud data centers are under extreme pressure to improve the efficiency of storage. To address this data center challenge, HGST introduces Ultrastar 7K6000, delivering plenty of capacity and a standard, 3.5-inch hard drive, for capacity-optimized enterprise applications. Ultrastar 7K6000 provides more capacity and better power efficiency. The Ultrastar 7K6000 also delivers great storage efficiency through the unrivaled performance, achieving higher write performance, even at higher workloads, thanks to HGST media cache architecture, a disk-based caching technology, which provides a large non-volatile cache on the disk. Media cache also allows for improved reliability and data integrity during unexpected power loss.
  • Increasing capacity density
    Ultrastar 7K6000 delivers plenty of capacity in a standard, 3.5-inch hard drive, for capacity-optimized enterprise applications. Ultrastar 7K6000 provides more capacity and better power efficiency. The 7K6000 is designed for traditional and rapidly growing scale-out storage applications, including object, block and file storage architectures, providing huge capacity, fast 7,200 RPM performance and the optimal acquisition cost.
  • The technology to improve storage efficiency
    Ultrastar 7K6000 also delivers great storage efficiency through its stunning performance, achieving higher random write performance, thanks to HGST media cache architecture, a disk-based caching technology, which provides a large non-volatile cache on the disk. Media cache also allows for improved reliability and data integrity during unexpected power loss. Other performance-enhancing feature is high areal density for faster sequential performance. The 7K6000 offers a 12 Gb/s SAS interface for easy integration into high performance data centers.
WD Ultrastar 7K6000 HUS726060ALE610 - hard drive - 6 TB - SATA 6Gb/s
Hard drive - internal
6 TB
3.5" x 1/3H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
128 MB
Spindle Speed
7200 rpm
Rotational Vibration Safeguard (RVS), Advanced Format technology, 24x7 continuous operation, Instant Secure Erase (ISE), media caching technology, Rebuild Assist mode, non-volatile cache
101.6 mm x 147 mm x 26.1 mm
715 g
5-year warranty
6 TB
3.5" x 1/3H
SATA 6Gb/s
Buffer Size
128 MB
Bytes per Sector
4096
101.6 mm
147 mm
26.1 mm
715 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
227 MBps
Seek Time
7.6 ms (average)
Average Latency
4.16 ms
Spindle Speed
7200 rpm
Reliability
MTBF
2,000,000 hours
24x7 Operation
Non-Recoverable Errors
1 per 10^15
Load / Unload Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
3.5" x 1/3H
Power Consumption
9.1 Watt (active) , 7.1 Watt (low power idle)
EcoTrac
Limited warranty - 5 years
5 °C
60 °C
Shock Tolerance (operating)
70 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
300 g @ 1 ms half-sine pulse
Vibration Tolerance (operating)
0.67 g @ 5-500 Hz
Vibration Tolerance (non-operating)
1.04 g @ 5-500 Hz
