HGST Travelstar Z5K500 500GB 7mm SATA 6B/s 5400RPM 8MB 2.5" Hard Drive
Quicklinx: B021WS00 Mfr#: 0J38065
Travelstar Z5K500 is the 5400 RPM 2.5-inch hard drive from Hitachi, with high capacity, and the Advanced Format drive. Advanced Format increases the physical sector size on HDDs from 512 bytes to 4,096 bytes, which improves drive capacities and error correction capabilities. The Z5K500 carries the EcoTrac classification due to its low-power consumption and eco-friendly, halogen-free production. Travelstar Z5K500 delivers the right balance of capacity, power-management and design flexibility to meet the needs of mobile applications.
WD Travelstar Z5K500 HTS545050A7E680 - hard drive - 500 GB - SATA 6Gb/s
Hard drive - internal
500 GB
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
8 MB
Spindle Speed
5400 rpm
TrueTrack servo technology, rugged, Advanced Format technology (2nd generation)
70 mm x 100 mm x 7 mm
95 g
Microsoft Certification
Compatible with Windows 7
500 GB
2.5"
SATA 6Gb/s
Buffer Size
8 MB
Bytes per Sector
512
70 mm
100 mm
7 mm
95 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
136 MBps
Seek Time
13 ms (average) / 25 ms (max)
Track-to-Track Seek Time
1 ms
Average Latency
5.5 ms
Spindle Speed
5400 rpm
Reliability
Start / Stop Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5"
Power Consumption
4.5 Watt (start) , 1.6 Watt (read) , 1.6 Watt (write) , 0.8 Watt (active idle) , 0.2 Watt (standby) , 0.1 Watt (sleep) , 0.55 Watt (low power idle) , 1.5 Watt (performance idle)
RoHS, REACH, halogen-free
60 °C
Shock Tolerance
400 g @ 2ms half-sine pulse
