Travelstar Z5K500 is the 5400 RPM 2.5-inch hard drive from Hitachi, with high capacity, and the Advanced Format drive. Advanced Format increases the physical sector size on HDDs from 512 bytes to 4,096 bytes, which improves drive capacities and error correction capabilities. The Z5K500 carries the EcoTrac classification due to its low-power consumption and eco-friendly, halogen-free production. Travelstar Z5K500 delivers the right balance of capacity, power-management and design flexibility to meet the needs of mobile applications.
- WD Travelstar Z5K500 HTS545050A7E680 - hard drive - 500 GB - SATA 6Gb/s
- Hard drive - internal
- Capacity
- 500 GB
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 8 MB
- Spindle Speed
- 5400 rpm
- TrueTrack servo technology, rugged, Advanced Format technology (2nd generation)
- 70 mm x 100 mm x 7 mm
- 95 g
- Microsoft Certification
- Compatible with Windows 7
- Capacity
- 500 GB
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- Buffer Size
- 8 MB
- Bytes per Sector
- 512
- 70 mm
- 100 mm
- 7 mm
- 95 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 136 MBps
- Seek Time
- 13 ms (average) / 25 ms (max)
- Track-to-Track Seek Time
- 1 ms
- Average Latency
- 5.5 ms
- Spindle Speed
- 5400 rpm
Reliability
- Start / Stop Cycles
- 600,000
Expansion & Connectivity
- 1 x SATA 6 Gb/s - 7 pin Serial ATA
- Compatible Bay
- 2.5"
- Power Consumption
- 4.5 Watt (start) , 1.6 Watt (read) , 1.6 Watt (write) , 0.8 Watt (active idle) , 0.2 Watt (standby) , 0.1 Watt (sleep) , 0.55 Watt (low power idle) , 1.5 Watt (performance idle)
- RoHS, REACH, halogen-free
- 0 °C
- 60 °C
- Shock Tolerance
- 400 g @ 2ms half-sine pulse
