HGST IDK Deskstar NAS H3IKNAS40003272SE Hard Drive 4TB 3.5"  SATA 6Gb/s
Quicklinx: BRL9WS00 Mfr#: 0S03665
The Deskstar NAS hard drive is a 7200 RPM 3.5-inch hard drive that provides an exceptional blend of reliability and performance, making it an ideal solution for consumer and commercial desktop NAS systems. This NAS-ready hard drive from HGST delivers media transfer rates that are as much as 20% faster than 5400 RPM drives and seek times less than 12 ms. Furthermore, Deskstar NAS hard drives incorporate a rotational vibration sensor and achieve reliability of 1M hours MTBF.
WD IDK Deskstar NAS H3IKNAS40003272SE - hard drive - 4 TB - SATA 6Gb/s
Hard drive - internal
4 TB
3.5" x 1/3H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
64 MB
Spindle Speed
7200 rpm
Enhanced Availability (EA) for 24x7 accessto data
10.16 cm x 14.7 cm x 2.61 cm
690 g
3-year warranty
4 TB
3.5" x 1/3H
SATA 6Gb/s
Buffer Size
64 MB
10.16 cm
14.7 cm
2.61 cm
690 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
1638 MBps
Spindle Speed
7200 rpm
Reliability
MTBF
1,000,000 hours
Non-Recoverable Errors
1 per 10^14
Load / Unload Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5" x 1/3H
Power Consumption
6.9 Watt (idle)
Limited warranty - 3 years
5 °C
60 °C
8 - 90% (non-condensing)
Vibration Tolerance
0.67 g @ 5-500 Hz (operating) / 1.04 g @ 2-200 Hz (non-operating)
