Ultrastar 7K4000 represents the sixth-generation HGST 5-platter design, which has been field proven by top server and storage OEMs and Internet giants. Engineered for the highest quality, the Ultrastar 7K4000 is put through grueling design tests during development and must pass stringent ongoing reliability testing during manufacturing. Ultrastar 7K4000 delivers by reducing downtime, eliminating service calls and minimizing TCO.
Operating at 7200 RPM, Ultrastar 7K4000 offers better overall performance than slower RPM capacity-oriented drives, and does so at impressively low power-consumption rates. The Ultrastar 7K4000 can help data centers achieve lower AC power and HVAC requirements. With five advanced power Management modes, the 7K4000 achieves a 59% reduction in watts during low RPM idle mode, and uses less than 1 W during standby/sleep modes, freeing up precious headroom for growing enterprise needs.
Delivering industry-leading quality and reliability
Ultrastar 7K4000 represents the sixth-generation HGST 5-platter design, which has been field proven by top server and storage OEMs and Internet giants. Engineered for the highest quality, the Ultrastar 7K4000 is put through grueling design tests during development and must pass stringent ongoing reliability testing during manufacturing. Ultrastar 7K4000 delivers by reducing downtime, eliminating service calls and minimizing TCO. -
Increasing capacity density by one third
To deal with the explosive petabyte (PB) growth, data centers require large amounts of efficient storage. Reducing W/GB without expanding floor space is vital to lowering operating costs. Now you can get 2.4 PB in the footprint of a standard 19-inch enterprise storage rack by stacking ten 4U, 60-bay enclosures. Ultrastar 7K4000 is an advanced format drive, using 4096-byte sector size to provide enormous capacity earlier than otherwise possible for environments optimized for this technology. Advanced format drives are backwards compatible with legacy 512-byte sector size by offering built-in 512-byte emulation through the SATA interface. -
Combining 7200 RPM performance and granular power control
Operating at 7200 RPM, Ultrastar 7K4000 offers better overall performance than slower RPM capacity-oriented drives, and does so at impressively low power-consumption rates. The Ultrastar 7K4000 can help data centers achieve lower AC power and HVAC requirements. With five advanced power Management modes, the 7K4000 achieves a 59% reduction in watts during low RPM idle mode, and uses less than 1 W during standby/sleep modes, freeing up precious headroom for growing enterprise needs. -
Innovating for a more sustainable environment
The Ultrastar 7K4000, with its halogen-free design and power-efficient operation, qualifies for the HGST EcoTrac classification, which identifies products that minimize environmental impact in the areas of product design, manufacturing, operation and disposal.
- WD Ultrastar 7K4000 HUS724040ALA640 - hard drive - 4 TB - SATA 6Gb/s
- Hard drive - internal
- Capacity
- 4 TB
- Form Factor
- 3.5" x 1/3H
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 64 MB
- Spindle Speed
- 7200 rpm
- Rotational Vibration Safeguard (RVS), Thermal Flyheight Control (TFC), Enhanced Availability (EA) for 24x7 accessto data, Advanced Format technology, Dual Stage Actuator (DSA), S.M.A.R.T.
- 10.16 cm x 14.7 cm x 2.61 cm
- 0.69 kg
- Microsoft Certification
- Compatible with Windows 7
- 5-year warranty
- Capacity
- 4 TB
- Form Factor
- 3.5" x 1/3H
- Interface
- SATA 6Gb/s
- Buffer Size
- 64 MB
- Bytes per Sector
- 512
- 10.16 cm
- 14.7 cm
- 2.61 cm
- 0.69 kg
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 181 MBps
- Seek Time
- 8 ms (average)
- Spindle Speed
- 7200 rpm
Reliability
- MTBF
- 2,000,000 hours
- Non-Recoverable Errors
- 1 per 10^15
- Start / Stop Cycles
- 600,000
Expansion & Connectivity
- 1 x SATA 6 Gb/s - 7 pin Serial ATA
- Compatible Bay
- 3.5" x 1/3H
- Power Consumption
- 11.4 Watt (active) , 5.7 Watt (idle)
- Limited warranty - 5 years
- 5 °C
- 60 °C
- Shock Tolerance
- 70 g @ 2ms half-sine pulse (operating) / 300 g @ 1ms half-sine pulse (non-operating)
- Vibration Tolerance
- 0.67 g @ 5-500 Hz (operating)
