Corporate and cloud data centers are under extreme pressure to improve the efficiency of storage. To address this data center challenge, HGST introduces Ultrastar 7K6000, delivering plenty of capacity and a standard, 3.5-inch hard drive, for capacity-optimized enterprise applications. Ultrastar 7K6000 provides more capacity and better power efficiency. The Ultrastar 7K6000 also delivers great storage efficiency through the unrivaled performance, achieving higher write performance, even at higher workloads, thanks to HGST media cache architecture, a disk-based caching technology, which provides a large non-volatile cache on the disk. Media cache also allows for improved reliability and data integrity during unexpected power loss.
Enhanced durability
Designed to withstand daily use, this hard drive has a shock acceleration (operating) of 70 g and a non-operating shock acceleration of 300 g, ensuring your data remains safe from physical impacts. -
Reliable performance
With an MTBF of 2,000,000 hours, users can rely on the WD Ultrastar 7K6000 for consistent performance over time. -
Efficient operation
Featuring an average latency of 4.16 ms and a spindle speed of 7200 rpm, this hard drive ensures quick access to data, enhancing productivity for demanding applications.
- WD Ultrastar 7K6000 HUS726060AL5210 - hard drive - 6 TB - SAS 12Gb/s
- Hard drive - internal
- Capacity
- 6 TB
- Hardware Encryption
- Form Factor
- 3.5" x 1/3H
- Interface
- SAS 12Gb/s
- Data Transfer Rate
- 1.2 GBps
- Buffer Size
- 128 MB
- Spindle Speed
- 7200 rpm
- Rotational Vibration Safeguard (RVS), Advanced Format technology, 24x7 continuous operation, Instant Secure Erase (ISE), media caching technology, Rebuild Assist mode, non-volatile cache
- 101.6 mm x 147 mm x 26.1 mm
- 715 g
- 5-year warranty
- Capacity
- 6 TB
- Form Factor
- 3.5" x 1/3H
- Interface
- SAS 12Gb/s
- Buffer Size
- 128 MB
- Bytes per Sector
- 512
- 101.6 mm
- 147 mm
- 26.1 mm
- 715 g
Performance
- Drive Transfer Rate
- 1.2 GBps (external)
- Internal Data Rate
- 227 MBps
- Seek Time
- 7.6 ms (average)
- Average Latency
- 4.16 ms
- Spindle Speed
- 7200 rpm
Reliability
- MTBF
- 2,000,000 hours
- 24x7 Operation
- Non-Recoverable Errors
- 1 per 10^15
- Load / Unload Cycles
- 600,000
Expansion & Connectivity
- 1 x SAS 12 Gb/s
- Compatible Bay
- 3.5" x 1/3H
- Power Consumption
- 11 Watt (active) , 7.7 Watt (low power idle)
- EcoTrac
- Limited warranty - 5 years
- 5 °C
- 60 °C
- Shock Tolerance (operating)
- 70 g @ 2 ms half-sine pulse
- Shock Tolerance (non-operating)
- 300 g @ 1 ms half-sine pulse
- Vibration Tolerance (operating)
- 0.67 g @ 5-500 Hz
- Vibration Tolerance (non-operating)
- 1.04 g @ 5-500 Hz
