HGST 500GB Touro Mobile 2.5" USB 3.0 Portable Hard Drive
Quicklinx: 9ZS9WS00 Mfr#: 0S03797
Touro Mobile external drive provides portable storage for all your photos, movies, music and documents. With Plug and Play simplicity, Touro Mobile comes with all the quality and reliability you expect from Hitachi.
WD Touro Mobile HTOLMU3EA5001ABB - hard drive - 500 GB - USB 3.0
Hard drive - external (portable)
500 GB
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0)
Spindle Speed
5400 rpm
Power Source
USB bus
80 mm x 115 mm x 13 mm
137 g
EMEA
Bundled with
3GB free Cloud Backup
500 GB
USB 3.0
80 mm
115 mm
13 mm
137 g
Bundled with
Performance
Interface Transfer Rate
Spindle Speed
5400 rpm
Expansion & Connectivity
1 x USB 3.0 - 9 pin Micro-USB Type B
Power Source
USB bus
Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Apple MacOS X 10.5 or later, Windows 8, Windows 8.1
1 x USB 3.0 cable - external
Plug and Play
EMEA
5 °C
35 °C
20 - 80% (non-condensing)
