Touro Mobile external drive provides portable storage for all your photos, movies, music and documents. With Plug and Play simplicity, Touro Mobile comes with all the quality and reliability you expect from Hitachi.
- WD Touro Mobile HTOLMU3EA5001ABB - hard drive - 500 GB - USB 3.0
- Hard drive - external (portable)
- Capacity
- 500 GB
- Interface
- USB 3.0
- Data Transfer Rate
- 5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0)
- Spindle Speed
- 5400 rpm
- Power Source
- USB bus
- 80 mm x 115 mm x 13 mm
- 137 g
- Localisation
- EMEA
- 2-year warranty
- Bundled with
- 3GB free Cloud Backup
- Capacity
- 500 GB
- Interface
- USB 3.0
- 80 mm
- 115 mm
- 13 mm
- 137 g
- Bundled with
Performance
- Interface Transfer Rate
- Spindle Speed
- 5400 rpm
Expansion & Connectivity
- 1 x USB 3.0 - 9 pin Micro-USB Type B
- Power Source
- USB bus
- OS Required
- Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Apple MacOS X 10.5 or later, Windows 8, Windows 8.1
- Cables Included
- 1 x USB 3.0 cable - external
- Plug and Play
- Localisation
- EMEA
- Limited warranty - 2 years
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
