Travelstar 5K1000 is a 5400 RPM, 500GB/platter, 2.5-inch hard drive. This standard 9.5mm, two-disk design, intended for use in notebook PCs, external storage, gaming consoles and other mobile applications, leverages advanced format, which increases the physical sector size on hard drives from 512 bytes to 4096 (4K) bytes to increase drive capacities and improve error correction capabilities.
Encryption option
Travelstar 5K1000 is the seventh generation self-encrypting drive (SED) to feature Hitachi's bulk data encryption. The SED encrypts data using protected keys in real time, providing users the highest level of data protection available. It also speeds and simplifies drive re-purposing. By deleting the encryption key, the data on the drive is rendered unreadable, thereby eliminating the need for time-consuming data-overwrite. -
Enhanced Availability (EA) - for 24x7 access to data
Hitachi provides enhanced availability models of the Travelstar 5K1000 that allow 24x7 access to data to support applications that require round-the-clock operation. The 5K1000 provides high capacity, durability and low power utilization on a proven platform for quality and reliability. EA models support the stringent demands of "always-on" applications in lower transaction environments.
- WD Travelstar 5K1000 HTS541010A9E680 - hard drive - 1 TB
- Hard drive - internal
- Capacity
- 1 TB
- Form Factor
- 2.5" x 1/8H
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 8 MB
- Spindle Speed
- 5400 rpm
- TrueTrack servo technology, Thermal Flyheight Control (TFC), Advanced Format technology
- 70 mm x 100 mm x 9.5 mm
- 102 g
- Microsoft Certification
- Compatible with Windows 7
- Capacity
- 1 TB
- Form Factor
- 2.5" x 1/8H
- Buffer Size
- 8 MB
- Bytes per Sector
- 512
- 70 mm
- 100 mm
- 9.5 mm
- 102 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 125 MBps
- Seek Time
- 12 ms (average) / 20 ms (max)
- Track-to-Track Seek Time
- 1 ms
- Average Latency
- 5.5 ms
- Spindle Speed
- 5400 rpm
Reliability
- Start / Stop Cycles
- 600,000
Expansion & Connectivity
- 1 x - 7 pin Serial ATA
- Compatible Bay
- 2.5" x 1/8H
- Halogen-free
- 0 °C
- 60 °C
- Shock Tolerance
- 225 g @ 1ms half-sine pulse (operating) / 1000 g @ 1ms half-sine pulse (non-operating)
