HGST 1TB Travelstar SATA 6GB/s 5400RPM 8MB 2.5" Laptop Hard Drive
Quicklinx: 9Z4MWS00 Mfr#: 0J22413
Travelstar 5K1000 is a 5400 RPM, 500GB/platter, 2.5-inch hard drive. This standard 9.5mm, two-disk design, intended for use in notebook PCs, external storage, gaming consoles and other mobile applications, leverages advanced format, which increases the physical sector size on hard drives from 512 bytes to 4096 (4K) bytes to increase drive capacities and improve error correction capabilities.
  • Encryption option
    Travelstar 5K1000 is the seventh generation self-encrypting drive (SED) to feature Hitachi's bulk data encryption. The SED encrypts data using protected keys in real time, providing users the highest level of data protection available. It also speeds and simplifies drive re-purposing. By deleting the encryption key, the data on the drive is rendered unreadable, thereby eliminating the need for time-consuming data-overwrite.
  • Enhanced Availability (EA) - for 24x7 access to data
    Hitachi provides enhanced availability models of the Travelstar 5K1000 that allow 24x7 access to data to support applications that require round-the-clock operation. The 5K1000 provides high capacity, durability and low power utilization on a proven platform for quality and reliability. EA models support the stringent demands of "always-on" applications in lower transaction environments.
WD Travelstar 5K1000 HTS541010A9E680 - hard drive - 1 TB
Hard drive - internal
1 TB
2.5" x 1/8H
Data Transfer Rate
600 MBps
Buffer Size
8 MB
Spindle Speed
5400 rpm
TrueTrack servo technology, Thermal Flyheight Control (TFC), Advanced Format technology
70 mm x 100 mm x 9.5 mm
102 g
Microsoft Certification
Compatible with Windows 7
1 TB
2.5" x 1/8H
Buffer Size
8 MB
Bytes per Sector
512
70 mm
100 mm
9.5 mm
102 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
125 MBps
Seek Time
12 ms (average) / 20 ms (max)
Track-to-Track Seek Time
1 ms
Average Latency
5.5 ms
Spindle Speed
5400 rpm
Reliability
Start / Stop Cycles
600,000
Expansion & Connectivity
1 x - 7 pin Serial ATA
Compatible Bay
2.5" x 1/8H
Halogen-free
60 °C
Shock Tolerance
225 g @ 1ms half-sine pulse (operating) / 1000 g @ 1ms half-sine pulse (non-operating)
