Touro Mobile: Portable storage for all your files.
Touro™ Mobile external drive provides portable storage for all your photos, movies, music and documents. With plug and play simplicity, Touro Mobile comes with all the quality and reliability you expect from Hitachi.
Hitachi Global Storage Technologies (Hitachi GST) develops advanced hard disk drives, enterprise-class solid state drives, and innovative external storage solutions and services to store, preserve and manage the world's most valued data.
- Portable storage for all your digital files
- Smooth, textured body for solid good looks
- Preformatted for PCs, easily reformatted for Macs
- Fast USB 3.0 Interface
- USB powered
- 2.5 inch External Hard Disk Drive
- Interface: USB 3.0 compliant, USB 2.0 compatible
- Dimensions: Product: 80mm (W) x 126mm (H) x 15mm (D)
- System Requirements: Windows: Computer system running with Windows® XP, Windows® Vista, or Windows 7TM and an available USB 2.0 or 3.0 port, Macintosh: Computer system running with Mac OS® 10.5 or newer and an available USB port
- 2 year warranty
Includes
- Touro Mobile external hard drive
- USB 3.0 cable
- Quick Start Guide
- WD Touro Mobile MX3 HTOLMX3EA10001ABB - hard drive - 1 TB - USB 3.0
- Hard drive - external (portable)
- Capacity
- 1 TB
- Form Factor
- 2.5"
- Interface
- USB 3.0
- Spindle Speed
- 5400 rpm
- Bus Powered by USB
- Power Source
- USB bus
- Enclosure Colour
- Black
- 8 cm x 12.6 cm x 1.5 cm
- Localisation
- EMEA
- 2-year warranty
- Capacity
- 1 TB
- Form Factor
- 2.5"
- Interface
- USB 3.0
- 8 cm
- 12.6 cm
- 1.5 cm
Performance
- Spindle Speed
- 5400 rpm
Expansion & Connectivity
- 1 x USB 3.0
- Compatible Bay
- 2.5"
- Power Source
- USB bus
- OS Required
- Microsoft Windows Vista / XP / 7, Apple MacOS X 10.5 or later
- Cables Included
- 1 x USB cable
- Enclosure Colour
- Black
- Localisation
- EMEA
- Limited warranty - 2 years
