Wireless Bluetooth Speaker
SIMPLICITY
Play the music stored on all your devices featuring the Bluetooth® wireless technology (smartphone, tablet or computer). It's simple, compact... and indispensable! Activate your smartphone's Bluetooth® feature, and the BT03 will connect easily.
WIRELESS
The BT03 speaker uses Bluetooth® technology, offering a 15 metre range (50'). You can take it with you everywhere inside your home - the music never stops.
COMPACT
Boasting a very compact size (only 23.5 cm long), the BT03 enables you to take your music with you everywhere inside your home - ideal for close-range, instant and ultra-simple listening.
STEREO
In spite of its small size, the 2.0 single-unit BT03 system offers ample power and a balanced audio rendition quality: true-to-life bass and realistic medium and treble.
MUSIC REMOTE
More comprehensive than any remote control, the WAE application enables you to manage your BT03 easily. Listening to music becomes nothing but pure pleasure. Every time this application is launched on AndroidTM, it automatically activates the smartphone's Bluetooth® connection, which then automatically connects to the speaker.
AUX input
The speaker features a 3.5 mm mini-jack input, enabling you to connect it to your MP3 player or any other music device.
- Bluetooth® EDR (A2DP) 2.0 audio system with Bluetooth® wireless technology
- Original and trendy design - Compact size to bring your music everywhere
- Two wide-range active drivers
- Dual bass ports located behind the grille
- Lacquered finish
- Embossed metal grille protecting the drivers
- Grip featuring a rubber insert, for comfortable transport
- Volume adjustment buttons on front of unit
- Bluetooth® pairing button on front of unit
- ON/OFF switch
- Auxiliary line input
- Included application to control the speaker with your smartphone or tablet
Technical specifications
Total power output: 2 x 6 W RMS
Peak power: 24 W
Frequency response: 80 Hz - 20,000 Hz
Satellite measurements: 12 (H) x 23.5 (W) x 10.5 (D) cm
Built-in power supply
Satellites with magnetic shielding for an interference-free environment
RoHS-standard compliant product
Box contents
1 single-unit Bluetooth®audio system
1 power cord
Warranty certificate and user manual
Simplicity
Play the music stored on all your devices featuring the Bluetooth wireless technology (smartphone, tablet or computer). It's simple, compact and indispensable! Activate your smartphone's Bluetooth feature, and the BT03 will connect easily. -
Wireless
The BT03 speaker uses Bluetooth technology, offering a 15 meter range. You can take it with you everywhere inside your home - the music never stops. -
Compact
Boasting a very compact size, the BT03 enables you to take your music with you everywhere inside your home - ideal for close-range, instant and ultra-simple listening.
- Hercules Wireless Audio Experience BT03 - speaker - for portable use - wireless
- Product Type
- Speaker - for portable use
- Speaker Type
- Active
- Nominal Output Power (Total)
- 12 Watt
- Audio System Peak Power (Total)
- 24 Watt
- Frequency Response
- 80 - 20000 Hz
- Amplifier
- Integrated
- Bluetooth
- Speaker Details
- Speaker - 6 Watt - active
- Black, orange
- 23.5 cm x 10.5 cm x 12 cm
- Product Type
- Enclosure Colour
- Black, orange
Speaker System
- Speaker Type
- Active
- Audio System Continuous Power (Total)
- 12 Watt
- 24 Watt
- 80 - 20000 Hz
- Magnetic Shield
- Amplifier
- Integrated
- Bluetooth 2.0 EDR
- Bluetooth Profiles
- Advanced Audio Distribution Profile (A2DP)
- Controls
- Power on/off, volume
Speaker System Details
- Speaker Details
- Driver Details
- 2 x full-range driver
- Connector Type
- Audio input
- Power Source
- AC power adapter
- 23.5 cm
- 10.5 cm
- 12 cm
