Henge Vertical Docking Station for 15" MacBook Pro
Quicklinx: BVD2WS00 Mfr#: HD04VA15MBPR
The Metal Edition dock features a solid construction of a high-density metal alloy, weighing in at a substantial 2.5 pounds (1.13 kg), and provides polished integration between your MacBook Pro with Retina Display and the docking station.
Henge Docks Metal Edition - port replicator - 2 x Mini DP
Port replicator
Video Interfaces
2 x Mini DP
16.2 cm x 26 cm x 13 cm
1.6 kg
Metal
Apple MacBook Pro with Retina display 15.4" (Mid 2012, Early 2013, Late 2013, Mid 2014, Mid 2015)
Port replicator
16.2 cm
26 cm
13 cm
1.6 kg
Enclosure Colour
Metal
1 x USB - 9 pin USB Type A , 1 x power - Apple MagSafe , 2 x Thunderbolt - Mini DisplayPort , 1 x audio - input - mini-phone 3.5 mm , 1 x audio - output - mini-phone stereo 3.5 mm
2 x Mini DisplayPort cable - external , 1 x USB cable - external , 1 x audio cable - external
