The Metal Edition dock features a solid construction of a high-density metal alloy, weighing in at a substantial 2.5 pounds (1.13 kg), and provides polished integration between your MacBook Pro with Retina Display and the docking station.
- Henge Docks Metal Edition - port replicator
- Product Type
- Port replicator
- 16.2 cm x 26 cm x 13 cm
- 1.6 kg
- Designed For
- Apple MacBook Pro with Retina display 15.4" (Mid 2012, Early 2013, Late 2013, Mid 2014, Mid 2015)
- Product Type
- Port replicator
- 16.2 cm
- 26 cm
- 13 cm
- 1.6 kg
- Enclosure Colour
- Metal
- 1 x USB - 9 pin USB Type A , 1 x power - Apple MagSafe , 2 x Thunderbolt - Mini DisplayPort , 1 x audio - input - mini-phone 3.5 mm , 1 x audio - output - mini-phone stereo 3.5 mm
- Cables Included
- 2 x Mini DisplayPort cable - external , 1 x USB cable - external , 1 x audio cable - external
- Designed For
