USB-Live2: a USB2 based video capture device for your Windows PC
Watch live video, grab images and movies plus videoconference* on your PC or Laptop
Bring live video into your PC from camcorder, VCR or video camera. Maximum video format size: 720x576 (PAL video).
Save still and motion video images to your hard disk.
Videoconference* over the Internet.
For Windows 7, Windows Vista and Windows XP.
USB-Live2 has lots of great features
A removable A/V cable set, so you can leave the cables connected to your A/V source while moving the USB-Live2 to a different computer. The A/V cable set attaches to USB-Live2 with a secure latching connector.
Indicator LEDs showing that USB-Live2 is powered on and a video signal is present.
Full 720x576 video mode (PAL).
Snap and print stills from whatever you're watching.
Record video clips from your camcorder or VCR to create your own high-impact presentations.
The easiest way to bring video into your PC or laptop!
Don't open your PC! USB-Live2 is an external device which connects your VCR, camcorder or video camera to your PC or laptop. Plug the USB-Live2 into the USB2 port and you're ready to watch video in a resizable window, right on your PC screen!
USB-Live2 digitizes video using high quality 4:2:2 video sampling. And you can work on applications while simultaneously watching video in a resizable window.
Watch, capture or record live video from your VCR, camcorder or video camera! USB-Live2 connects to any S-Video or composite video source and plugs into your PC or laptop's USB port. USB-Live's video digitizer turns your analogue video into digital video, and then sends 30 digital images per second over the USB 2.0 bus.
Add video clips to your Web Page. Creative Webmasters can incorporate still frame video highlights or motion video clips on their web sites!
Desktop Publishing. With our exclusive WinTV SnapShot function, you can quickly save JPEG video images! Also great for web design.
Model numbers:model 01383: USB-Live2 with English manual
System RequirementsPC with 2.8 GHz single-core or multi-core 1.8GHz.Microsoft® Windows® 7, Windows Vista or Windows XP (service pack 3).USB 2.0 port. CD-ROM drive for software installation.
Video digitizer: 720x480 for NTSC, 720x576 for PAL
Video source: S-Video or composite video
Audio input: left and right audio 50cm USB cable
USB-Live connects to any S-Video or composite video source and plugs into your PC or laptop's USB port. USB-Live's video digitizer turns your analog video into digital video, and then sends 30 digital images per second over the USB (1.1 or 2.0) bus. -
Spice up your multimedia presentations
Create digital movies in the Microsoft AVI file format with Hauppauge's WinTV Capture application. The included Ulead DVD MovieFactory allows you to edit and author DVDs, VideoCDs and S-VCDs. -
Add video clips to your WebPage
Creative Webmasters can incorporate still frame video highlights or motion video clips on their web sites! -
Desktop publishing
With THE exclusive WinTV SnapShot application, you can quickly save video images! Capture 24-bit still video still images in TIFF, JPEG, BMP in color or black/white. It is also great for web design.
- Hauppauge WinTV USB-Live2 - video capture adapter - USB 2.0
- Video capture adapter
- Interface Type
- USB 2.0
- Video Input
- S-video input, composite video input
- Analogue Video Format
- NTSC, PAL
- Video Compression Format
- YUV 4:2:2
- Digital Video Format
- AVI
- Digital Video Capture Resolution
- 720 x 480, 720 x 576
- Audio Input Support
- Standard
- Built-in LED lights
- OS Required
- Microsoft Windows XP SP2, Microsoft Windows 7, Microsoft Windows Vista
- 2-year warranty
- Interface Type
- USB 2.0
Video
- Interface Type
- NTSC, PAL
- YUV 4:2:2
- AVI
- Image Recording Format
- JPEG, BMP, TIFF
- Standard
- 1 x display / video - S-video input - on cable , 1 x display / video - composite video input - RCA - on cable
- Connections
- 1 x USB 2.0 - 4 pin USB Type A
- Cables Included
- 1 x A/V cable - external - 1 cm , 1 x USB cable - 50 cm
- Software Included
- Ulead DVD MovieFactory, WinTV 7
- OS Required
- Additional Requirements
- CD-ROM, USB port
- System Requirements Details
- Windows XP/Vista/7 - Pentium - 2 GHz
- Limited warranty - 2 years
