Plug the WinTV-soloHD into a USB port on your Windows PC or laptop and you can watch, pause & record Freeview High Definition and Standard Definition TV.
For Freeview HD (DVB-T2), Freeview (DVB-T) and DVB-C digital TV
Plug the WinTV-soloHD into a USB port on your Windows PC or laptop and you can watch, pause & record Freeview High Definition and Standard Definition TV. The WinTV-soloHD can receive Freeview HD (DVB-T2), Freeview SD (DVB-T) and "free-to-view" digital cable TV (DVB-C) on your Windows PC. In addition to live over-the-air Freeview HD TV(DVB-T2), the WinTV-soloHD can also receive DVB-T. If you live in an area which does not broadcast the high definition DVB-T2 signal yet, you can watch the standard Freeview DVB-T and upgrade to DVB-T2 when it comes to your area. -
Never miss your favorite TV show again
The WinTV-soloHD comes with the WinTV v8 application for Windows. With WinTV v8, you can watch or record your favorite TV programs in your PC, in a window or full screen. TV recordings made with the WinTV-soloHD are recorded in the original digital format, without any loss in quality. Recordings can be scheduled with the built-in TV scheduler in WinTV v8. -
The WinTV-soloHD turns your PC into a high definition DVR
Plug the WinTV-soloHD into your PC and turn it into a digital video recorder (DVR). With the included WinTV v8 application, you can watch HD or SD TV on your PC screen, in a window or full screen. A built-in Electronic Program Guide (EPG) allows you to see what's on TV now and what's coming up. Schedule TV recordings with WinTV v8's built-in TV scheduler. Pause live TV and record your favorite TV programs in the full digital TV format.The WinTV-soloHD is fully backward compatible to DVB-T and delivers outstanding reception for both DVB-T and DVB-T2 broadcast standards.
- Hauppauge WinTV soloHD - digital TV tuner - USB 2.0
- Digital TV tuner - DVB-C, DVB-T2 - HDTV
- Interface Type
- USB 2.0
- Electronic Program Guide (EPG)
- OS Required
- Microsoft Windows 7 / 8 / 8.1 / 10
- Interface Type
- USB 2.0
Video
- 1 x antenna - IEC connector
- Connections
- 1 x USB 2.0 - 4 pin USB Type A
- Device Features
- USB powered
- Software Included
- WinTV v8
- OS Required
