Hauppauge WinTV Nova-TD 500 Dual digital DVB-T PCI TV card
Customer rating: 4.0* (Write a review)
Quicklinx: 45KFWS00 Mfr#: 289
WinTV-NOVA-T-500, the dual digital DVB-T receiver for your PC! WinTV-NOVA-T-500 is a high sensitivity dual DVB-T receiver. Connect a digital TV aerial to the WinTV-NOVA-T-500, and you can watch and record DVB-T digital TV on your PC, in a window or full screen. With the dual digital tuners on WinTV-NOVA-T-500, you can record one digital TV channel while watching another. Or record two digital TV programs at once!
Hauppauge WinTV NOVA-T-500 - digital TV tuner - PCI
Digital TV tuner - DVB-T
Compatibility
MS Windows XP Media Centre compatible, MS Windows Vista Media Center compatible
Interface Type
PCI
Included Input Adapter Accessories
Remote control, IR receiver
Digital Video Format
MPEG-2, DVB
Electronic Program Guide (EPG), dual tuner
Microsoft Windows XP SP2, Microsoft Windows Vista, Microsoft Windows Vista (64-bit versions)
Microsoft Certification
Certified for Windows Vista
Compatibility
Interface Type
PCI
Video
MPEG-2, DVB
Audio Input
Digital radio tuner
1 x TV antenna - input , 1 x remote control - input
Compatible Slots
1 x PCI
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
Software Included
Drivers & Utilities, WinTV-Scheduler, WingSE
Additional Requirements
Sound card, CD-ROM, 64MB video memory
Customer reviews
Write a review for the Hauppauge WinTV Nova-TD 500 Dual digital DVB-T PCI TV card here!
stop worrying...
Reviewed by Greg Neumann. Review Posted 30/05/2008
Just bought 2 of these dual tuners for two different machines and both are (now) working.
In the first install, a VISTA Home Premium setup but on an 'old' motherboard (circa 3-4 years old design), I ran into the "device not installed" problem whereby the bios doesn't recognise the card and so VISTA has no chance of installing drivers. Moved the card to another PCI slot. No change. Moved Tuner to yet another PCI slot (slot 1!) - and the device was recognised which, together with the latest drivers off Hauppauge web site, then installed effortlessly and tuned in both tuners via Media Centre first time.
Second install - another VISTA premium but on a much more modern GIGABYTE board. Recognized and installed drivers first time and tuned into Media Centre no hassle.
Stop worrying; card is fine but you need to have some way of investigating IF you get install problems - that's the nature of this technical area. If this scares you, got for an external USB TV Tuner and clutter your desktop!
  • Overall 5*
  • Ease of use 4*
  • Value for money 4*
Does exactly what it says on the tin (well, Box actually...)
Reviewed by powerarmour. Review Posted 02/01/2008
Lucky to have received the Single antenna/VIA IC/Linux Compatible version... :)
Works fine/tested in MythTV, but using it 24/7 in Vista Home Premium 32bit Media Center with the latest 4.3.25080 drivers without any issues at all, both tuners detected and as long as you have decent signal strength you wont get any stutter.
Much better than my previous Hauppauge HVR-1110 for Vista MCE use, recommended.
  • Overall 5*
  • Ease of use 3*
  • Value for money 5*
Works Well
Reviewed by Chris Shaw. Review Posted 07/12/2006
Using Windows Media Center 2005, this works well. Unlike the Terratec Cinergy 2400 that I have just ditched for repeated signal bombs...
  • Overall 5*
  • Ease of use 5*
Read all 15 customer reviews
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
