Hauppauge WinTV-NOVA-T Digital DVB-T USB Stick
WATCH AND RECORD DIGITAL FREEVIEW TV ON YOUR PC
Customer rating: 4.0* (Write a review)
Quicklinx: 42PGWS00 Mfr#: 294
1 on order, delivery delayed
Watch Free-to-View digital TV (terrestrial) on your PC or laptop, in a window or full screen.
  • Digital TV offers sharper pictures and clearer sound.
  • Record digital TV programmes to disk in an MPEG-2 format. Play them back on your PC screen, or record to CD/DVD!
  • Listen to digital stereo radio.
  • USB 2.0 Plug & Play for easy installation on laptop and desktop PCs. No external power needed!
  • Full support for Microsoft Media Center
  • Live Free-to-View Digital TV on your on your laptop or desktop PC screen - in a resizeable window or full screen. Free-to-View digital TV does not require a PayTV subscription.
  • Listen to Digital stereo radio on your PC or laptop.
  • Record your digital TV shows to your PC's hard disk using high quality MPEG-2 compression. Play them back on your PC screen or burn them onto CD or DVD (DVD/CD burners not included).
Watch Free-to-View digital TV and digital radio stations* directly on your laptop or desktop PC! WinTV-NOVA-T-Stick is a Plug & Play USB device which brings digital terrestrial broadcasts (TV and radio) to your PC. Digital reception provides sharper TV pictures and near CD quality audio. And Free-to-View digital TV does not require a PayTV subscription!
WinTV-NOVA-T-Stick turns your PC monitor into a high quality digital TV receiver. You can watch digital TV broadcasts in a window on your PC screen, or watch TV full screen. Record your digital TV shows to disk, and play them back at any time. You can also listen to digital radio in stereo*.
Note: WinTV-NOVA does not support DAB radio.
Add Digital TV to your Media Center PC or notebook. If you have a Media Center PC or notebook with or without a built-in TV tuner, simply plug the WinTV-Nova-T-Stick, install the MCE drivers from the supplied CD, and you will be watching digital TV with Media Center 's MyTV button in no time! Note: Media Center Decoder not supplied.
WinTV-NOVA-T-Stick is simple to connect to your PC or laptop. Just plug it into your PC's USB 2.0 port, connect a digital TV aerial, install the WinTV applications and you're ready to watch and record high quality digital TV!
Why Digital TV? Digital Television is the TV of the future. Building on your existing five channels, digital television offers many extra free channels including BBC Choice, ITV2, BBC Knowledge and BBC News 24, with others on the way.
Digital terrestrial television (DTT) is a robust, all-digital system, unlike the current analogue PAL TV system. For the first time, studio quality television can be viewed on your desktop.
WinTV-NOVA, your Personal Digital VCR: WinTV-NOVA can record your digital TV programs to disk. And with WinTV Scheduler, you can schedule your TV recordings. Recorded programmes take approximately 1.2GB of hard disk space per hour.
You can also burn your TV recordings onto a CD or DVD-ROM. A CD-ROM will hold about 30 minutes of digital TV, while a recordable DVD will store about 2 1/2 hours of digital TV. Note: Dvd/CD authering software not included.
Note: Recommend a rooftop aerial to receive full reception
  • Minimum processor 1.2 GHz Intel® or equivalent.
  • Microsoft® Windows® 7 (32/64bit), Vista (32/64bit) or Windows XP Service Pack 3.
  • Graphics with 64 MB of memory (minimum).
  • Sound card or on board sound.
  • USB 2.0 port (will not work with USB 1.1).
  • CD-ROM drive (for Software installation).
Included in the box
* WinTV-NOVA-T-Stick USB2 adapter, with highly sensitivity DVB-T tuner.
* Software on CD-ROM.
* Quick Installation Guide.
The WinTV-NOVA-T-Stick does not support DAB radio
For Digital Terrestrial reception, a high gain aerial is recommended
Hauppauge WinTV NOVA-T-Stick - digital TV tuner - USB 2.0
Digital TV tuner - DVB-T
Interface Type
USB 2.0
Included Input Adapter Accessories
TV aerial
Video Input
USB 2.0
Digital Video Format
MPEG-2, DVB
Time shift function
Microsoft Windows 7, Microsoft Windows XP SP3, Microsoft Windows Vista (32/64 bits)
Microsoft Certification
Certified for Windows Vista
Interface Type
USB 2.0
Video
TV tuner
Interface Type
USB 2.0
MPEG-2, DVB
Time shift function
Audio Input
Digital radio tuner
1 x TV antenna
1 x USB 2.0 - 4 pin USB Type A
TV aerial
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
Customer reviews
Write a review for the Hauppauge WinTV-NOVA-T Digital DVB-T USB Stick here!
Rather Good I Say!
Reviewed by Chris Frenzel. Review Posted 14/06/2007
Expected it to be not that good, but after upgrading one of my workstations to vista, and having to change the audio card, get a new graphics card I found the TV card still did not work so a new one of them was required – what to get? (Apart from a new PC in the first place) Well this was cheap so I went for one. And it’s pretty good but as all digital receivers “You Must Have A Good Signal” and the latest drivers! The app that drives it is the same as for all the Hauppauge cards so if you don’t like it you won’t like anything from them and I agree it has some shortfalls but it’s good enough for me. So the idea that you can stick it in your pocket and go any ware with it – well if there is no signal then it’s just a lump of plastic.
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Good Bit Of Kit
Reviewed by Richard. Review Posted 28/07/2007
I bought this item today and it works well. The only thing I would advise people not to do is download the drivers form the web site if you are using Windows XP. The drivers on the web site do not let you allow to scan for any channels rendering the device useless. Stick to the CD that comes with the tuner. Version 3.3B works like a dream and I reinstalled it for problem free viewing.
  • Overall 5*
  • Ease of use 5*
Amasing TV!
Reviewed by James Preston. Review Posted 31/10/2007
Among the cheapest DVB-T tuners available but don’t let that throw you, the WinTV interface (viewer) is easy to use and the picture quality is fine on a AMD 1.6Ghrz Single Core Processor.
Only thing it misses is a Remote Control but at this cost I wasn’t expecting one!
Over all 10/10!
  • Overall 5*
  • Ease of use 5*
Read all 13 customer reviews
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
