If you live in an area where you can receive Freeview digital TV, the WinTV-HVR-2200 supports digital TV watching, pause, recording and playback on your PC's screen.
If you live in an area where you can't currently receive Freeview digital TV, the WinTV-HVR-2200 can still be used to watch and record analog TV from cable or a TV aerial. But you are prepared for the future! When digital TV comes to your area, WinTV-HVR-2200 will also receive the new digital TV channels.
If you live in an area where you can receive both analog cable plus Freeview digital TV, you have the best of both worlds! Watch analog and digital TV on your PC screen, in a window or full screen.
- Hauppauge WinTV HVR-2200 - digital / analogue TV tuner / radio tuner / video capture adapter - PCIe
- Digital / analogue TV tuner / radio tuner / video capture adapter - DVB-T
- Interface Type
- PCIe
- Analogue Video Format
- SECAM, PAL
- Digital Video Format
- MPEG-2, DVB
- OS Required
- Microsoft Windows XP, Microsoft Windows XP Media Center Edition, Microsoft Windows Vista
- Microsoft Certification
- Certified for Windows Vista
- Interface Type
- PCIe
Video
- SECAM, PAL
- MPEG-2, DVB
Audio Input
- FM tuner
- 1 x audio - input , 1 x video - S-video input , 1 x video - composite video input , 1 x TV antenna - input , 1 x FM antenna - input
- Compatible Slots
- 1 x PCI Express
- Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
- Supported Windows 7 Features
- Windows Media Center
- Plug and Play
- Software Included
- Drivers & Utilities
- OS Required
- Additional Requirements
- Sound card, CD-ROM, AGP graphics card
