Watch, capture or record live video from your VCR, camcorder or video camera! USB-Live connects to any S-Video or composite video source and plugs into your PC or laptop's USB port. USB-Live's video digitizer turns your analog video into digital video, and then sends 30 digital images per second over the USB (1.1 or 2.0) bus.
Spice up your multimedia presentations! Create digital movies in the Microsoft AVI file format with Hauppauge's WinTV Capture application. The included Ulead DVD MovieFactory allows you to edit and author DVDs, VideoCDs and S-VCDs.
Creative Webmasters can incorporate still frame video highlights or motion video clips on their web sites!
With THE exclusive WinTV SnapShot application, you can quickly save video images! Capture 24-bit still video still images in TIFF, JPEG, BMP in color or black/white. It is also great for web design.
USB-Live connects to any S-Video or composite video source and plugs into your PC or laptop's USB port. USB-Live's video digitizer turns your analog video into digital video, and then sends 30 digital images per second over the USB (1.1 or 2.0) bus. -
Create digital movies in the Microsoft AVI file format with Hauppauge's WinTV Capture application. The included Ulead DVD MovieFactory allows you to edit and author DVDs, VideoCDs and S-VCDs. -
Add video clips to your WebPage
Creative Webmasters can incorporate still frame video highlights or motion video clips on their web sites! -
Desktop publishing
- Hauppauge WinTV USB-Live2 - video capture adapter - USB 2.0
- Video capture adapter
- Interface Type
- USB 2.0
- Localisation
- English, German, French
- Video Input
- S-video input, composite video input
- Analogue Video Format
- NTSC, PAL
- Video Compression Format
- YUV 4:2:2
- Digital Video Format
- AVI
- Digital Video Capture Resolution
- 720 x 480, 720 x 576
- Audio Input Support
- Standard
- Built-in LED lights
- OS Required
- Microsoft Windows XP SP2, Microsoft Windows 7, Microsoft Windows Vista
- Microsoft Certification
- Certified for Windows Vista
- 2-year warranty
- Interface Type
- USB 2.0
- Localisation
Video
- Interface Type
- NTSC, PAL
- YUV 4:2:2
- AVI
- Image Recording Format
- JPEG, BMP, TIFF
- Standard
- 1 x display / video - S-video input - on cable , 1 x display / video - composite video input - RCA - on cable
- Connections
- 1 x USB 2.0 - 4 pin USB Type A
- Cables Included
- 1 x A/V cable - external - 1 cm , 1 x USB cable - 50 cm
- Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
- Software Included
- Ulead DVD MovieFactory, WinTV 7
- OS Required
- Additional Requirements
- CD-ROM, USB port
- System Requirements Details
- Windows XP/Vista/7 - Pentium - 2 GHz
- Limited warranty - 2 years
