Hauppauge PCTV Broadway HD S2
Quicklinx: 814VWS00 Mfr#: 23108
Broadway HD-S2 is a member of the Broadway product family, bringing you lives satellite TV on your Apple or Android mobile device - at home via Wi-Fi or around the world via the Internet. Broadway HD-S2 is a small standalone device which connects to your satellite dish or your standalone pay-TV set-top-box. While connected to your local home network it sends live-TV to your.
  • Stream satellite-TV wirelessly to your iPad or iPhone
    Broadway streams live satellite-TV via your home router to your mobile Android-device, iPad or iPh-one device wherever you are. TV streaming works in your home network (Wi-Fi) as well as over the Internet.
  • Stream satellite-TV wirelessly to your Mac or PC
    Broadway also streams satellite-TV to your Mac, Windows- or Linux PC - simply via the installed web browser. No need to install any additional apps or programs!
  • Stream live cam video
    Connect a camera to Broadway and stream live video and audio from your home via 3G or Wi-Fi directly to your smartphone, tablet, PC or Mac.
PCTV Broadway HD-S2 - digital TV tuner / video capture adapter - Ethernet, 802.11n
Digital TV tuner / video capture adapter - DVB-S2
Interface Type
Ethernet, 802.11n
18.5 cm x 18.5 cm x 10 cm
800 g
Included Input Adapter Accessories
Power adapter
Analogue video Signal
S-Video, composite video
Digital Video Format
MPEG-2, MPEG-4, H.264
Microsoft Windows Vista / XP / 7, Apple MacOS X 10.5 or later, Ubuntu 11.x, Android 2.2 or later, Apple iOS 3.0 or later
Interface Type
Ethernet, 802.11n
18.5 cm
18.5 cm
10 cm
800 g
Video
1 x audio / video - composite video input - RCA x 3 , 1 x video - S-video input - 7 PIN mini-DIN , 2 x USB - 4 pin USB Type A , 1 x satellite antenna - F connector
1 x network - Ethernet - RJ-45
Power adapter
1 x network cable - external
System Requirements Details
Windows XP/Vista/7 - 1.5 GHz
