Hauppauge myTV 2GO-m
FREEVIEW TV FOR YOUR APPLE MOBILE. NO 3G DATA USE
Quicklinx: 86H3WS00 Mfr#: 01390
Watch and record live Freeview TV on your new iPad, iPad 2 and iPhone 4S*!
Plug-in and Go! Just connect to your new iPad, iPad 2 and iPhone 4S*. It's that simple!
Watch and live Freeview Digital TV on your new iPad, iPad 2 and iPhone 4S, in your home while moving around, in the kitchen, in the garden, when you are out and about, in fact anywhere with a DVB-T Freeview signal. myTV 2GO-m is an exclusive product for new iPad, iPad 2 and iPhone 4S.
To install, simply plug myTV 2GO-m into the power connector on your new iPad, iPad 2 and iPhone 4S. Then download our free app from the Apple app store and scan for Freeview TV broadcasts in your area.
myTV 2GO-m's built in antenna can be used to receive Freeview TV within approx 10 miles of a Freeview broadcast transmitter, depending on location.
Record your live Freeview TV programmes, too! With the free EPG built-in the application, see a guide of upcoming digital TV programmes. Pause live TV (Time Shifting) at any time, or record your favourite Freeview TV programmes!
Note: In order to record, your new iPad, iPad 2 and iPhone 4S must be turned on.
myTV 2GO-m includes the latest generation digital terrestrial TV tuner, giving you the best TV experience. myTV 2GO-m also includes its own battery to allow TV watching up to 9 hours with an iPad 2 in airplane mode.
myTV 2GO-m is small enough to fit in your pocket yet powerful enough to give you the freedom to watch what you want where you want, for hours.
myTV 2GO-m does not require a dataplan to operate. Receive unlimited live Freeview DVB-T TV on your new iPad, iPad 2 and iPhone 4S without using your data allowance.
myTV 2GO-m is easy to setup!:
Connect your myTV 2GO-m directly to your new iPad, iPad 2 and iPhone 4S
Install the TV app from the app store (no charge)
Follow the simple setup menus. Then start watching TV*!
Note: *Where you get sufficient DVB-T (Freeview) reception
