WinTV-MiniStick is small in size but includes a powerful built-in digital TV receiver. Inside WinTV-MiniStick is the latest high sensitivity DVB-T receiver for great TV reception at home or when you travel. WinTV-MiniStick can be used with the included portable DVB-T antenna, or you can use a rooftop aerial for the best digital reception.
Watching digital TV on a PC or laptop has never been simpler: just plug WinTV-MiniStick into your computer's USB 2.0 port, connect a digital TV antenna or aerial, install the WinTV application and in minutes you're ready to watch and record Freeview digital TV on your computer screen!
WinTV v7 is a digital video recorder, too! Record digital TV programs to disk in their original digital quality and play them back to your PC screen at any time. Use the built-in TV scheduler to automatically record your favorites TV shows, on a daily, weekly or once only schedule. You can even play back videos without a WinTV being plugged into your laptop, so you can watch recorded TV programs when you travel!
- Hauppauge WinTV MiniStick SE - digital TV tuner - USB 2.0
- Digital TV tuner - DVB-T
- Interface Type
- USB 2.0
- Included Input Adapter Accessories
- TV aerial, remote control
- Video Input
- USB 2.0
- Digital Video Format
- MPEG-2, DVB
- Audio Input Support
- Standard
- Remote control, Electronic Program Guide (EPG)
- OS Required
- Microsoft Windows 7
- 2-year warranty
- Interface Type
- USB 2.0
Video
- Interface Type
- USB 2.0
- MPEG-2, DVB
- Standard
- 1 x TV antenna - input
- Connections
- 1 x USB 2.0 - 4 pin USB Type A
- Included Accessories
- OS Required
- Limited warranty - 2 years
