Hauppauge HD-PVR
Hauppauge HD-PVR
1080I COMPONENT HD GAME CAPTURE FOR PS3 AND XBOX
Quicklinx: 58XWWS00 Mfr#: 01228
Record your high definition TV programs to your PC, using high quality H.264!
HD PVR is the world's first High-Definition video recorder for making real-time H.264 compressed recordings at resolutions up to 1080i. HD-PVR records component video (YCrCb) from cable TV and satellite set top boxes, with a built-in IR blaster to automatically change TV channels for scheduled recordings. Audio is recorded using AAC or Dolby Digital.
The recording format is AVCHD, which can be used to burn Blu-ray DVD disks. Two hours of HD recordings, recorded at 5 Mbits/sec, can be burnt onto a standard 4.7 GByte DVD-R or DVD-RW disk for playback on a Blu-ray DVD player.
The HD PVRs amazing recording quality allows personal archival of your favourite high definition TV programs from any component video HD set top box. The HD PVR also has standard definition composite and S-Video inputs so you can record your old home video tapes into an AVCHD format for creating Blu-ray DVD recordings.
  • Processor Requirements (minimum): Dual core CPU
  • Graphics with 256MB memory (or greater)
  • Note: the playback of high definition H.264 requires a fast CPU and at least 256MB of graphics memory
  • Sound card
Included with the HD PVR
  • HD PVR high definition personal video recorder, USB
  • IR Blaster transmitter cable
  • Component video cable set
  • Audio cable set
  • USB cable
  • 5v power supply
Bundled software applications
  • Arcsoft "TotalMediaExtreme" for video capture, preview, playback, and authoring and burning your TV recordings onto a Blu-ray DVD compatible disc.
  • Arcsoft "TotalMedia Theater", a video player so you can play back your TV recordings to your PC screen.
  • Arcsoft "MediaConverter" , to convert your H.264 HD recordings onto other formats.
  • Includes Hauppauge's WinTV scheduler for scheduled TV recordings.
Hauppauge HD PVR - video capture adapter - USB 2.0
Video capture adapter
Interface Type
USB 2.0
19.8 cm x 17.3 cm x 7 cm
Included Input Adapter Accessories
Power adapter
Video Input
S-video input, composite video input, component video input, component video output, USB 2.0
Analogue Video Format
NTSC, SECAM, PAL
Analogue video Signal
S-Video, composite video, component video
Digital Video Format
AVCHD, H.264
Audio Input Support
Standard
Microsoft Certification
Certified for Windows Vista
Interface Type
USB 2.0
19.8 cm
17.3 cm
7 cm
Video
Interface Type
NTSC, SECAM, PAL
AVCHD, H.264
Audio Input Support
Standard
1 x display / video - S-video input - 4 pin mini-DIN - front , 1 x display / video - composite video input - RCA - front , 1 x audio - line-In - RCA x 2 - front , 1 x audio - line-out - RCA x 2 - rear , 1 x audio - line-In - RCA x 2 - rear , 1 x display / video - component video input - RCA x 3 - rear , 1 x display / video - composite video output - RCA x 3 - rear , 1 x audio - SPDIF input - TOSLINK - rear , 1 x audio - SPDIF output - TOSLINK - rear
1 x USB 2.0 - 4 pin USB Type B
Power adapter
1 x component video cable - external , 1 x audio cable - external , 1 x USB cable - external
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
Software Included
WinTV-Scheduler, ArcSoft TotalMedia Extreme, ArcSoft TotalMedia Theatre, ArcSoft MediaConverter
Additional Requirements
Sound card, 256 MB video memory
