- HANNS.G HL225DNB - LED monitor - Full HD (1080p) - 21.5"
- LED-backlit LCD monitor - 21.5"
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.248 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- 600:1 / 5000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA
- Tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- 50.4 cm x 13 cm x 31 cm
- 3.2 kg
- 3-year warranty
- Display Type
- Diagonal Size
- 21.5"
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.248 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 56 - 75 Hz
- Horizontal Refresh Rate
- 30 - 82 kHz
- Horizontal Viewing Angle
- +90 / -90
- Vertical Viewing Angle
- +65 / -65
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Volume, brightness, input select, colour temperature
- Game mode, Cinema Mode
- 3.2 kg
- VGA , DVI-D
Mechanical
- Tilt
- Tilt Angle
- -5/+15
- VESA Mounting Interface
- 100 x 100 mm
- Wall mountable, LED indicator
- Included Accessories
- Stand
- Cables Included
- 1 x VGA cable - 1.5 m
- Input Voltage
- Power Consumption Stand by
- 0.5 Watt
- Limited warranty - 3 years
- 5 °C
- 35 °C
- 20 - 70% (non-condensing)
