HANNSG HP191DJ0 19" 1280 x 1024 5ms DVI-D VGA LCD Monitor with Speakers
Quicklinx: 71GGWS00 Mfr#: HP191DJ
Marketing description is not available.
HANNS.G HP191DJ0 - HP Series - LCD monitor - 19"
LCD monitor - 19"
Aspect Ratio
5:4
Native Resolution
1280 x 1024
Pixel Pitch
0.294 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 15000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Height, tilt
Screen Coating
Anti-glare
Voltage
AC 120/230 V (50 - 60 Hz)
Silver
41 cm x 20.3 cm x 39.3 cm
5 kg
Environmental Standards
ENERGY STAR Qualified
GOST, GS, CB, RoHS
Display Type
LCD monitor / TFT active matrix
Diagonal Size
19"
Aspect Ratio
5:4
Native Resolution
1280 x 1024
Pixel Pitch
0.294 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Anti-glare
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish, Dutch, Japanese, Korean
HDCP
Silver
5 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1 Watt
VGA , DVI-D (dual link) , Audio line-in
Mechanical
Height, tilt
Tilt Angle
20
Height Adjustment
60 mm
VESA Mounting Interface
1 x VGA cable , 1 x audio cable
GOST, GS, CB, RoHS
Input Voltage
Power Consumption (Typical)
25 Watt
Power Consumption Stand by / Sleep
1 Watt
Sustainability Information
ENERGY STAR Certified
5 °C
35 °C
20 - 85%
